Rear Defroster
TheFox
57
I took my dash out to fix some wiring problems this winter and when I did it was cold enough that the wires running to my defroster switch pulled out of the connector? Is there a place I can find the order they go in the connector?? Same with the fog light connector?? They just snapped so I need a new connector. Is there some place I can get these connectors.
Please help.
Kaleb
I don't have a diagram for the Defrost switch, but if you look inside the back of the switch housing by the terminals you should see the letters B, D, J, U.
The terminals go to the corresponding wire colors:
B - P/O
D - GY/LB
J - BR/LB
U - P (The switch is probably missing this terminal, but the connector may still contain a purple wire.)
The foglight switch has the letters B & L.
B - LB/BK
L - T/O
