The 1987-88 Turbo Coupes had their own unique 8.8" axle equipped with rear disc brakes. The width of the axle housing itself was identical to the Cougar 8.8" with drums. All TC 8.8" rears had Quad shocks and Traction-Lok. Cars with 5-speed transmissions had a 3.55 gear; automatics had the 3.73 ratio (a clue while searching for on in salvage yards is that all 1987-88 5-speed Turbo Coupes had dual exhaust, whereas the automatics had single exhaust). All TC's had standard ABS brakes which necessitated several sensors to be installed on the rear end, along with an exciter ring on each rear axle shaft, thus making the rear axles wider. Installing a Turbo Coupe rear as-is requires conversion to rear disc brakes and modifications to the existing brake system. However, all ABS-related hardware will not work. It is possible to convert this axle to drum brakes using other Ford drums and hardware. Since there were quite a few TC's made, the TC rear is plentiful in supply but usually costs a bit more due to the rear discs. If you cannot find a stock 8.8" Cougar rear end with drum brakes, then making one out of a Turbo Coupe rear is indeed a viable alternative.
