  • 1994 - 1995 Specific Tech
Rear. diff. cover and fluid ?? friction modifier?
  • Thread starter Thread starter Ryan Paterick
  • Start date Start date Apr 26, 2004
Ryan Paterick
943
  • Apr 26, 2004
Having the rear diff fluid changed. Do I need to add the friction lock fluid in?
I just don't know if we have traction lock. I'm guessing we do. Sorry for the dumb thread on this btw.
JJ95GTID
1,141
Phoenix, AZ
Apr 26, 2004
  • Apr 26, 2004
If you still have stodk gears there should be a little silver tab attached to one of the diff cover bolts. If it says 2L73 or 3L08 or 3L27 then you have a Traction Lok carrier and need the 4oz bottle of friction modifier. Or you could check the numbers on the driver's side door jam and see if you have a Trac Lok.
Ryan Paterick
943
  • Apr 26, 2004
Thanks, and what should I be looking for on the door, or is it obvious?
M
musclecarmaniac
26
Minny Soh Ta
Apr 26, 2004
  • Apr 26, 2004
an easy way to tell if you have a limited slip (traction-lok) differential is to jack the back of the car up and then put it in nuetral. spin the back tires forward by hand if they both spin the same way you have traction lok if they dont you have an open diff. i hope this helps.
JJ95GTID
1,141
Phoenix, AZ
Apr 27, 2004
  • Apr 27, 2004
Under the 'AX' there should be a letter or number. For 94 models K, M, R, W, and Z are limited slips and for 95 models E, M, and Z are the limited slip models. This is from a Chilton's manual for 1994-98 Mustangs.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Sunday at 10:03 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:58 PM
nicholase
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
