I want to convert my rear brakes to disk, and the 3 common vehicles Ive heard of that make for an easy swap are the 96+ Exploder, 92-96 Crown Vic, and Mark VII. I was going to use the Crown Vic setup, but walking through the U-pick yard this afternoon I saw a Mark and noticed that it actually has vented rotors. So whats the basic pros and cons of each? As far as I can tell...
1. Explorer-
...Positive- Good strong setup, internal park brake is easy to work on, plentiful and fairly cheap.
...Negative- Kinda heavy, have to redrill caliper brackets, non-vented rotors.
2. Crown Vic- this is what I was going to use
...Positive- Lighter than Ex setup, but still very adequate, no need to redrill brackets, simple internal park brake, common as dirt, cheap.
...Negative- Still no vented rotors, some have mentioned reclocking one side???
3. Mark VII- this is the one I know less about
...Positive- vented rotors!
...Negative- less common, expensive and P.I.T.A. integral park brake
1. Explorer-
if i were going to keep the stang then i'd put a set of cobra or mkvii brakes on it and but the kit from you since i'd never even consider pulling a boat with the stang but the cougar's a little different story.
