  • 1994 - 1995 Specific Tech
Rear end diagram?
  • Thread starter Thread starter GregW
  • Start date Start date Aug 3, 2006
G
GregW
  • Aug 3, 2006
I have a (new to me) 95 Mustang GT. There is a roaring noise coming from the rear end whether it is under load or not. I "assume" it is a wheel bearing (axle bearing ) that has or is going bad. I have never replaced a bearing on a Mustang but I "assume" it is the same (or close) to a GM product. Is this correct? Does anyone have a diagram I could reference? ( I do not have a service manual yet BTW :~>)
Ford dealer wants $500 to start (they want to tear it down and replace all the items they think need replacing) . I believe I can do it cheaper then that :~>
Any suggestions, thoughts or pointers appreciated.
Thanks,
greg
parchisi
519
New Mexico
Aug 3, 2006
  • Aug 3, 2006
You can just go to an auto parts store and get a Chiltons, or another thing that I did, I bought a Ford Service manual on CD from e-bay. It has exploded view diagrams of pretty much everything.
As far as getting somebody else to do it, I had an Eaton posi, new axles and new bearings put in for $300 labor. Just ask around your area for a reputable drivetrain shop and go there.
parchisi
519
New Mexico
Aug 3, 2006
  • Aug 3, 2006
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 3, 2006
  • Aug 3, 2006
trac-loc blow up......
G
GregW
  • Aug 4, 2006
Thanks !!!
I appreciate it. I 'think" I can do it:~>
greg
Bosko5.0
1,067
longwood, FL
Aug 5, 2006
  • Aug 5, 2006
its very easy to do, it good to have help. me and my brother replaced both bearings and axle shafts(bent a shaft) in about hour and half, it also good to have 4oz of friction modifer and synthetic rear gear oil.
94-302-vert
1,947
NE CT
Aug 8, 2006
  • Aug 8, 2006
If you are going to go that far, may as well do gears at the same time...
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Rear end noise while driving low and high speeds
  • skkrtis
  • Apr 7, 2025
2005 - 2014 S-197 Mustang -General/Talk- Feb 9, 2026
Broncin491
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
