Rear End Girdle.
  • Thread starter Thread starter 86bluecobra
  • Start date Start date Apr 7, 2007
1 of 2 Next Last
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 7, 2007
  • Apr 7, 2007
Thinking of buying a rear end girdle. (diff cover with preloads for bearings)
Which one should I go out and buy?
Ford Racing?
Trick Flow?
Moroso?
Summit Racing house Brand?
TA?
Which one do you own and how do you like it?
4G-KDMP
935
CA
Apr 7, 2007
  • Apr 7, 2007
there all a copy of the ta cover.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 7, 2007
  • Apr 7, 2007
funny you should say that I was just searching ebay motors and I came across the TA girdle.
4G-KDMP
935
CA
Apr 7, 2007
  • Apr 7, 2007
buy it!
the rest are a spin off of the ta cover.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 7, 2007
  • Apr 7, 2007
I have the Summit Brand, they were out of the Trick Flow Girdle when I placed my order so they gave me that one instead, I like it. I did have to grind down one of the support ribs as a bolt would not fit in.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 7, 2007
  • Apr 7, 2007
Stupid Double Post
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Apr 8, 2007
  • Apr 8, 2007
I have a summit one. Exact same as the Trick Flow girdle. Nice piece. I like it a lot.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 8, 2007
  • Apr 8, 2007
LPW here. No problems, fit just fine.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2007
  • Apr 8, 2007
The trickflow girdle looks like it has long studs that are the perloaders. The Ford Racing and moroso look like they have allen key studs with a nut locker. Is this the case?
jgfiveoh
102
Topeka, KS
Apr 8, 2007
#10
  • Apr 8, 2007
  • #10
the FRPP has allen key studs that have a large flat landing on a ball and socket that is the actual part that preloads the caps.and a hex locking nut. nice piece comes with mounting hdw(not stainless). doesn't have magnetic fill and drain plugs like some
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 8, 2007
#11
  • Apr 8, 2007
  • #11
Ok now that I have asked which is better and I guess i'm getting the answer that they are all the same besides the fact you get a fill and drain plug in the rear which i really like what is it going to do for me. Why do you need to load the bearings? Does this prevent damage to the gears themselves?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 9, 2007
#12
  • Apr 9, 2007
  • #12
I was going to buy one just for the drain plug.....I would change my diff fluid way more often just cause it would be alot quicker.
ronburgundy
179
BC coast
Apr 9, 2007
#13
  • Apr 9, 2007
  • #13
you load the bearings, because under launch if a cap goes, your carrier gets spit strait back. the girdle supports this area some. besides, the girdles look so cool you're sure to gain at least 10 hp lol.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 9, 2007
#14
  • Apr 9, 2007
  • #14
I thought the 10HP was from the stickers that come with it.
ronburgundy
179
BC coast
Apr 9, 2007
#15
  • Apr 9, 2007
  • #15
lol. 15 if they're yellow stickers. remember, yellow = horsepower.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 9, 2007
#16
  • Apr 9, 2007
  • #16
Well I ordered the T/A girdle. Now I have to finish the rebuild.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Apr 9, 2007
#17
  • Apr 9, 2007
  • #17
I have one on the Cobra. Don't use it with a gasket, because it will leak. Just use good old RTV. I wouldn't wast your money though.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 9, 2007
#18
  • Apr 9, 2007
  • #18
I bought the Ford Racing Rubber Gasket when I ordered my Cover, it worked great!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 9, 2007
#19
  • Apr 9, 2007
  • #19
I use "The Right Stuff" I put a nice bead around the cover and wait about an hour than fill the diff. A rubber gasket should work fine but I wouldn't waste my time with the cork ones
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 9, 2007
#20
  • Apr 9, 2007
  • #20
yes I have seen how well cork worked with my valve covers and my pan gasket. Now they are nice rubber ones. I will just use RTV silicone like I always do. It hasn't let me down yet.
1 of 2 Next Last
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
