Rear-End Help!!!
  • Thread starter Thread starter SLEEPERstang21
  • Start date Start date Apr 9, 2006
SLEEPERstang21
204
Sunny California
Apr 9, 2006
  • Apr 9, 2006
I am looking to replace my rear-end on my '67. It used to be a straight 6 and still has the old rear-end. What are other rear-ends that I can use from other vehicles that will fit properly?
D
danny clemens
728
  • Apr 9, 2006
If you want it to be the correct width you can use an 8" or 9" out of a 67 thru 70 Mustang or Cougar. There probably are others.
SLEEPERstang21
204
Sunny California
Apr 9, 2006
  • Apr 9, 2006
I heard that I can also use a Granada. Is this true?
DukeGnarley
597
Auburn/Ellensburg, Wa
Apr 9, 2006
  • Apr 9, 2006
run a search, there was a thread about what 9" rear will work just last week.
shelbe67
309
Apr 10, 2006
  • Apr 10, 2006
you can use an 8.8 outa a 94-98 stang. just cut off the control arm mounts and weld on spring perches and you are good to go! thats what I did plus you get rear disc brakes
geostang351
946
Danb., CT
Apr 15, 2006
  • Apr 15, 2006
I have an 8" out of a 78 granda with 3.00 gears. Easy swap. I believe this rear is slightly narrower then a standard 8" in a 68
T
ttoney
195
Denver
Apr 15, 2006
  • Apr 15, 2006
http://www.mustangsandmore.com/ubb/FordRearDimensions.html
F
Flyin'Fastback
Louisiana
Apr 15, 2006
  • Apr 15, 2006
The center-to-center measurement for the spring perches is the same for the Granada and the '67 Mustang, though the overall length of the Granada axle housing is a bit shorter. It'll fit, and as a bonus you'll be able to fit *slightly* wider wheel/tire combos in back.
ultrastang
1,092
Arkansas
Apr 16, 2006
  • Apr 16, 2006
Any 8- or 9-inch rear end from a '67-'70 Mustang, or '67-'70 Cougar would be a direct fit. (54¼" bare housing width).
If you want a little more wheel clearance, you could install a '57-'59 Ford big car 9-inch rear end, '65/'66 Mustang/Falcon rear end, '75-'80 Granada/Mercury Monarch 8- or 9-inch rear end, or '77-'80 Lincoln Versailles 9-inch. All these rear ends have a 52¼" bare housing width --same as the '65/'66 Mustangs, and all rear ends listed have spring perches on 43" centers --same as '65-73 Mustangs.
http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
D
What's it Worth? Considering Selling '82 Fairmont Futura Body Shell
  • DonMay63
  • Apr 5, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Apr 5, 2026
DonMay63
D
