  • SN95 4.6L Mustang Tech
Rear end noise
  • Thread starter Thread starter f8tlfiveo
  • Start date Start date Mar 5, 2012
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Mar 5, 2012
  • Mar 5, 2012
Just bought a 2000 v6 with a blown trans... Put a new trans in... Runs and drives and shifts good.. When I am going straight no noise, when I am in a parking lot or making a semi hard turn I get a constant squealing noise. I figured it could be in the rearend because as soon as I turn it makes the noise. 1 wheel spins faster than the other when turning. The guy I bought it from told me the gears were replaced and he thought a posi unit was put in.. He didn't know what brand.. Could have been a factory unit. I dont know. Anybody have a similar issue.
Black'02
100
Rochester, NY
Mar 6, 2012
  • Mar 6, 2012
I had a similar issue on my GT. It sounded like dying baby seal inside the car as i was taking a sharp slow corner. If your V-6 has a limited slip diff in it, then it is possible that the noise is coming from the clutch packs in the diff. I tried replacing the gear oil at first and it didnt help. Changed the clutch packs and it took care of the noise.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Mar 6, 2012
  • Mar 6, 2012
It has a tracloc in it... The guy I bought it from didn't really know what was going on.. It was just put in, in October apparently... I am not keeping the car I just bought it cause it was an easy fix.. Now I got this noise I have to take care of before it goes for sale. Thanks for the reply. I figured it is going to be the diff or a brake problem..
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Mar 25, 2012
  • Mar 25, 2012
Got it figured out.. Thanks to your reply. The clutch packs looked a little burnt. They had hotspots on them. I took them all out. Put it back together.. The noise is gone. Now I have a different problem, I took the spring off of the calipers for the ebrake. I didn't put them back on cause it was a pain in the ass. I went for a short drive and could smell the brakes when I got back. Has anyone ever taken this spring off?
vertigasen
366
18
29
Falcon, CO
Mar 25, 2012
  • Mar 25, 2012
Hang on. You removed them, not replaced them? The spring is necessary. That is what disengages the brakes when you release the handle. If you push the button, with a working spring, the handle should want to pull down on its own. If you dont have the springs, when you push the button, you have to push the handle down and the brakes dont completly release. Sure you are going to smell brakes.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Mar 26, 2012
  • Mar 26, 2012
Yeah I took them off when I took the e cable off. Had to pull the axles to get the diff out.. I know what the spring is for, I just was taking the car for a test drive. I just need to figure out how to put the springs back on.. Looks like a pain.. I still have the springs
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Mar 30, 2012
  • Mar 30, 2012
Got them back on with a pair of channel lock pliers.. Big ones.. I took the bolt that holds the one side of the spring in and ground off the one side. That way It was easier to get the spring on, then tightened the bolt so the spring wouldnt come off.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 26, 2026
nicholase
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
