rear end options?
  • Thread starter Thread starter sallystrothers
  • Start date Start date Nov 28, 2008
sallystrothers
21
  • Nov 28, 2008
I have a 91 LX with a factory rear end and I noticed when I lay down the throttle it seems I am spinning only 1 tire out. I am looking both to increase the gear ratio to 3.73 and to get more locking of th axles. Here are my 2 options I was thinking of doing:
1. Buy a complete 8.8" rear end with traction lok
2. Rebuild my 7.5" rear end, changing the gears out also. My question is did the Fox mustangs already have some sort of differential locking and mine is not working right? If I went with this option what would I need to do to restore traction to both wheels?
D
Deleted member 87397
Nov 28, 2008
  • Nov 28, 2008
Is the car a 5.0 or was it a former 4 cylinder? If it's 5.0 then you already have an 8.8 Trac-Loc. If you are getting the one wheel peel your clutches in the rearend are worn out and it just needs a rebuild. If you are going to rebuild stock 8.8 then throw some better gears in at the same time. Can't go wrong with a set of Ford Racing 3.73's.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
D
Drivetrain Where to place jackstands when servicing rear diff
  • dqureshi06
  • Oct 16, 2025
Fox 5.0 Mustang Tech Nov 2, 2025
limp
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
