  • SN95 4.6L Mustang Tech
rear end problemo
  • Thread starter Thread starter stangfl
  • Start date Start date Jun 27, 2005
stangfl
20
FL
Jun 27, 2005
  • Jun 27, 2005
A few months ago I had my car on blocks for about a month to replace the motor, anyways after that my rear end has leaked. How big or small of a problem is this, something that I can do myself or ? Any advice would be helpful.
Thanks
96WhiteNight
303
Carlisle, PA
Jun 27, 2005
  • Jun 27, 2005
If its just leaking out of the rear end cover. Pull it off and re-seal it. Simple job i think its like 8-10 bolts. Make sure to fill the fluid back up
stangfl
20
FL
Jun 27, 2005
  • Jun 27, 2005
Quick question, I'm not to familiar with the back end of the car as much as the front but, do i need a gasket to seal it ? or some stuff in a tube? and the dumbest question.. where on the rear end do i fill the fluid up at.
Thanks
J
jayhawk261
18
Lenexa, KS
Jun 27, 2005
  • Jun 27, 2005
Some people use a gasket, some use ultra-blue silicone. I use a gasket with a thin film of ultra blue on each side.
The fill hole on an 8.8" rear axle is on the front side above the "equator" & on the drivers side I think. It is a pipe type plug that a 3/8" drive extension will fit into.
You want to fill it up to just below the hole.
96WhiteNight
303
Carlisle, PA
Jun 27, 2005
  • Jun 27, 2005
Exactly I do mine the same way
stangfl
20
FL
Jun 27, 2005
  • Jun 27, 2005
Thanks a lot for the help, where would I get the gasket --- ford or a local auto part store?
Thanks
96WhiteNight
303
Carlisle, PA
Jun 27, 2005
  • Jun 27, 2005
yea your local auto parts store should have it
R
rjstaaf
1,310
Somewhere
Jun 27, 2005
  • Jun 27, 2005
The rear end comes from the factory without a gasket under the cover and I have always done mine with Permatex Ultra Blue without any leaking whatsoever. It is a matter of personal preference I guess.
You should be able to find Permatex Ultra Blue at any auto parts store.
http://www.permatex.com/auto/autouh.asp?automotive=yes&f_call=get_item&item_no=81724
Here is a pretty good article on changing the diff fluid. It has lots of pictures and I believe one of them shows the location of the fill plug.
http://www.bullittarchive.com/html/modules/articles/article.php?id=71
FEARED
...but won't that hurt you?
Apr 1, 2005
29
Valley of The Sun
Jun 27, 2005
  • Jun 27, 2005
While your at it you may want to check the pinion seal too. I just replaced mine this weekend with relative ease. You would probably see oil on the rear of the mufflers and also just behind the receiving flange (Drive shaft bolts to it).
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
