  • SVT Tech Forum
rear end question
  • Thread starter Thread starter seths99cobra
  • Start date Start date Jun 12, 2011
seths99cobra
92
afghanistan
Jun 12, 2011
  • Jun 12, 2011
hey guys im not familiar with rear ends but i destroyed the rear end in my 99 cobra and all the gears are done for what i need is a complete list of all the gears and what not. thanks
P
Price1
109
Dryfork, WV
Jul 15, 2011
  • Jul 15, 2011
I'd suggest you try to find one in the junks. Any Mustang SRA has the same internal components as the Cobra's. Did you break your rear cover, too? If so, you can get an aftermarket one from LPW. I think the stock '99 has 3.23 gears like my '01. Exactly what did you break in there? Can you re-use the Fork Trac-Loc differential?
03Stangr
98
  • Jul 16, 2011
I was under the impression that the 99's had the IRS and if so you can get a custom 3rd member at; Approx. $899
Ford Custom 3rd Members : JTs Parts & Accessories, Justdifferentials.com
If not then I suggest doing what was mentioned and go to a salvage yard and search for the lowest mileage rear end config. parts for you car. Personally I've not done this because I couldn't find one that had low miles on it and just didn't trust what I was about to buy. Some people just tear their rear ends apart via abuse. Common for us Mustang people though. That's why if you're going to race a lot then get a 9" is what my suggestion is. Then you'll have the flexibility of swapping out third members for approx. $599 depending on where you go of course
seths99cobra
92
afghanistan
Aug 16, 2011
  • Aug 16, 2011
I broke the actual differential inside the housing that's all I broke ring and pinion was still re useable. I do have the irs in my car.
jeremy canter
402
Orange County , NY
Aug 22, 2011
  • Aug 22, 2011
then any 8.8 rear with the 28 spline gears should fit in to your housing > I would take the time and upgrade > even a little better than stock to hold more power or the power you have now better than the STOCK parts
sorry to hear of your bad luck .
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Thursday at 6:01 PM
Fox 5.0 Mustang Tech Friday at 9:42 PM
General karthief
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
  • SVT Tech Forum
