Rear End Ratio?
  • Thread starter Thread starter custompony
  • Start date Start date Jul 13, 2011
C
custompony
9
  • Jul 13, 2011
I have a 68 coupe that will have a 302 hooked up to a T-5 from a '90 mustang. I am planning on changing to an 8.8 rear end and am wondering what the ideal rear end ratio would be? I do a pretty even mix of freeway and city driving.
sdmustangrider
23
San Diego
Jul 13, 2011
  • Jul 13, 2011
I've been interested in a T-5 lately, and from what I hear, 3.73 is pretty good for both if it comes for a 8.8. I'm running a C4 3.40 Ford 8 and it's not THAT bad.
blown65
1,938
Queen Creek Arizona
Jul 13, 2011
  • Jul 13, 2011
At least 3.73's. Personally I'd probably run 4.10s cause even in 5th your going to have nice highway rpms and in the lower gears great performance. 1st is going to be kinda short though with the 4.10s depending on the gearing of your T5.
65fastbackresto
1,229
AR
Jul 13, 2011
  • Jul 13, 2011
I have T-5 and 355 rear
I can shift from 4th to 5th at 70 mph and it`ll drop to almost 2000rpm`s, which for my motor, is kinda lugging it. If I could do it over I`d prob go 411`s.
robbz28
775
Epps, LA
Jul 13, 2011
  • Jul 13, 2011
That will have a good bit to do with your camshaft and your engines "happy spot", also the ratio of your T5, since they vary some. If you have a fairly bone stock 302 then 3.55-3.73's will probably do wonderful, but if your engine is modded and likes higher RPM's then 3.73-4.11's. Lots of guys on here with that swap.
65fastbackresto
1,229
AR
Jul 13, 2011
  • Jul 13, 2011
Thats my problem,, motor is built for top end
I can either run 55mph or 80mph in its happy spot. It gets pretty scary over 100mph though, its like too much motor not enough car.
Fstbk
215
  • Jul 13, 2011
Here is a handy calculator that may help?
jlangholzj
Mustang Master
Oct 23, 2006
248
31
93
MI
Jul 13, 2011
  • Jul 13, 2011
this. I've got a fairly standard HCI 289 and with the o/d ratio of an AOD and 3.00 gears it was at about 1200 rpm. I'm planning on putting 3.73's in as I've ridden in other mustangs with a similar setup and it seems to be well. with the .76/1 of the AOD and 3.73 gears we were seeing about 1800-2k at speeds of 60mph or so. But it climbs out of the hole mighty fast
C
custompony
9
  • Jul 13, 2011
That thing is awesome. Right now at 80mph in 5th I'm at 2k. Definitely looks like 3.73 or thereabouts is gonna be great for me. Thanks for the responses.
blown65
1,938
Queen Creek Arizona
Jul 14, 2011
#10
  • Jul 14, 2011
  • #10
We run 4.56's with our AOD car and its still 2500-2600 at 60-65mph. Not too bad IMO for a classic. However its set up for the rpms that motor sees.
jcode68
892
Massachussetts
Jul 14, 2011
#11
  • Jul 14, 2011
  • #11
I'm running 3.73's with my T5 and think it is the perfect ratio. If you plan to spend time on the strip, you might want to go steeper, but for street driven, I have no regrets.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 2 3 4
1974 - 1978 Mustang II Talk & Tech Yesterday at 9:47 PM
LILCBRA
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
68 coupe rear drop
  • Butchd88
  • Apr 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 19, 2026
C.R.M.
