Rear Ends
  • Thread starter Thread starter Cobain03
  • Start date Start date Dec 6, 2004
Cobain03
996
Lexington, Ky
Dec 6, 2004
  • Dec 6, 2004
i was wantin to change out my 2.8 open diff to somethin a lil bit better.
like a 3.0 to 3.5 limited slip (or maybe locked if cheap enough) i was told that the sn95 models are wider then my 65 so those are out of the question right? what if i foundone and jsut used the gears out of it? would that work?
please point me in thhe right direction (cheap direction too lol)
6Stang7
1,470
Livermore, CA
Dec 6, 2004
  • Dec 6, 2004
Well, sadly with the rear end, going cheap will come back big time to bit you in the ass. Unless you spend around $400 for a locker, you will get some POS. You can buy a used 3rd member with the gear ratio you want and just swap it. You can also use a SN95 rear end, but you will have to pay a shop to shorten it to it fits. Plus you will have to have the proper mounts welded on which means proper pinion angle. Cheap way in my mind and best is to look in the paper or on ebay for rebuilt 3rd member with the ratio you want and with LSD. As for what gears, well that depends. If you have a T-5 or some tranny with overdrive and want some more performance geared then get 4.11's. If you want a little of both, then 3.55's or 3.73's.
G
GaPonyFarm
663
Columbus, GA
Dec 7, 2004
  • Dec 7, 2004
Why not just put a 3.55 trac-loc in the 8" you already have? You're not running enough power to break it, unless you get stupid,
Cobain03
996
Lexington, Ky
Dec 7, 2004
  • Dec 7, 2004
im still using my c4 tranny 3 spd auto. i dont really know what it would be like to change gears in mine thats why i was hoping to find an old one at a junkyard or somethin. was any early mustangs (65/66 i guess) have a lsd?
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
D
supercharging my v6 4.0
  • dreamerv6stang
  • Jan 12, 2025
  • The Welcome Wagon
The Welcome Wagon Jul 21, 2025
tovlux6
T
Drivetrain Rear end Question
  • Aoneill5.0
  • Nov 3, 2022
2K
Fox 5.0 Mustang Tech Nov 5, 2022
Rdub6
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Really? Basic question about my rear end....
  • Cammer429
  • Sep 4, 2021
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 7, 2021
Cammer429
