Rear Ends
Cobain03
996
Lexington, Ky
i was wantin to change out my 2.8 open diff to somethin a lil bit better.
like a 3.0 to 3.5 limited slip (or maybe locked if cheap enough) i was told that the sn95 models are wider then my 65 so those are out of the question right? what if i foundone and jsut used the gears out of it? would that work?
please point me in thhe right direction (cheap direction too lol)
Well, sadly with the rear end, going cheap will come back big time to bit you in the ass. Unless you spend around $400 for a locker, you will get some POS. You can buy a used 3rd member with the gear ratio you want and just swap it. You can also use a SN95 rear end, but you will have to pay a shop to shorten it to it fits. Plus you will have to have the proper mounts welded on which means proper pinion angle. Cheap way in my mind and best is to look in the paper or on ebay for rebuilt 3rd member with the ratio you want and with LSD. As for what gears, well that depends. If you have a T-5 or some tranny with overdrive and want some more performance geared then get 4.11's. If you want a little of both, then 3.55's or 3.73's.
im still using my c4 tranny 3 spd auto. i dont really know what it would be like to change gears in mine thats why i was hoping to find an old one at a junkyard or somethin. was any early mustangs (65/66 i guess) have a lsd?
