rear gears question
  • Thread starter Thread starter 88stanggonebad
  • Start date Start date Apr 27, 2006
88stanggonebad
59
  • Apr 27, 2006
im getting ready to order rear gears for my 1967 mustang w/ 289 and a c4 tranny and a 8" rear. i was thinking 4.11 but i would like to know how high my rpm's would be at say 65mph. i wont be doing to much freeway driving but but it might. would i be better off with 3.80 or 3.55?
iskwezm
4,159
20
79
Rowland Heights,California
Apr 27, 2006
  • Apr 27, 2006
I think a 3.80 is better, it will turn about 3200 st freeway speeds if i can remember(went to a 5 speed)
HookandLadder
261
St Louis
Apr 27, 2006
  • Apr 27, 2006
Depends on the tire you are running, but 3.50's are much easier on the motor for highway miles.
65notch
303
661 Cali
Apr 28, 2006
  • Apr 28, 2006
i went with 3.55s with my c4. i have a mild 289 and i was turning about 3200-3300 or so at around 65. it was pushing it a lil, i would stick with 3.55s, dont go any higher unless you plan to get an overdrive or 5spd.
i wish i would have gone with 380s because i just swaped to a 5spd, but gears arent to much money so i may change them out again later on.
mfp4073
387
Hells Ditch, FL
Apr 28, 2006
  • Apr 28, 2006
my 3.89s are about 4000rpms at 80, i think 3.55s would be a little more enjoyable for me.
rbohm
6,698
550
204
tucson,az
Apr 28, 2006
  • Apr 28, 2006
unless this is a race car, stick with 3.55's. that is the lowest all around gear you need for a car as light as your stang. anymore is a waste.
FORCED2DV8
458
Grand Rapids MI
Apr 28, 2006
  • Apr 28, 2006
3.55's are the most you want to go on the street, You will be around 3200 rpms depending on tire size. Even if you have a 5 speed they will drop to 2300 or so.
68RCodeConv
345
Houston, TX
Apr 28, 2006
  • Apr 28, 2006
I have 4.11 in my 67 GT350. Believe me, you don't want them on the freeway.
For a mostly stock 289, 3.55 is plenty. If the motor has been built to rev to 6000 or more then you might consider 3.75 or 3.89.
66moneypit
536
Northern Va
Apr 28, 2006
  • Apr 28, 2006
http://www.stanginfo.com/Gears/GearOptions_view.php
57fairlane
560
Oakwood, GA
Apr 28, 2006
#10
  • Apr 28, 2006
  • #10
I couldn't decide so I went with a 3.80. I run 275/60/15s (28") on the skreet which gives me an effective gear of 3.56s. Then at the track I switch tire sets to a 275/50/15 ET Street radial to use the extra gear.
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
