It will be pushing it though if you don't have an OD, but the gain is worth it.
Ronstang said:Actually you traction problem at the track with worsen when you go from 3.89s to 3.50s, not the other way around.
cobra1 said:traction has nothing to do with your rear end gear ratio.
We cannot tell you our thoughts unless we know alot more about your car.vobraman said:What size rear gears are most people using ? I have a 9" with 3.50 and I am thinking about 3.89 or 4.11. Just wondering what others are thinking.
thanks
Vinyl66 said:Why do you think traction would be more of a problem with higher (lower numerically) gears? That makes no sense.
Ronstang said:You guys are thinking about the traction/gear relationship all wrong, HP/torque does play a role but it is much harder to get the tires spinning with a low gear ratio because the tires have to spin more times per 1 revolution of the driveshaft and the spinning is also harder to maintain up to high rpms for the very same reason.....think about it. If you couldn't spin the tires with a 2.80 gear but you can with a 3.89 that proves nothing but the fact that your cam is too big to produce enough low end touque to get the tires spinning in the first place with the 2.80 gears but the 3.89 gears put you in your torque curve so you can. Highway gear ratios put very little load on the drivetrain and once you get them spinning they just keep spinning if you have enough HP but 4.11s definitely will not do the same.
Ronstang said:If you couldn't spin the tires with a 2.80 gear but you can with a 3.89 that proves nothing but the fact that your cam is too big to produce enough low end touque to get the tires spinning in the first place with the 2.80 gears but the 3.89 gears put you in your torque curve so you can.
ratio411 said:Think of the gears as a lever...
If you use a 5' lever to move a rock that weighs 1 ton, you struggle and eventually roll it without fan-fare.
If you use a 12' lever to move the same rock, you have more mechanical advantage, so the rolls quickly and easily without you pulling your back muscles.
That is what lower gears do. They give you a longer lever to move your weight. They multiply torque, so you put more torque to the ground with less effort... that is why the traction is lost with lower gears.
See, I do remember some automotive schooling! To think I was so chemically altered that time of my life, I barely remember my wedding day.
Dave
