I'm pretty sure I know what the problem is, but wanted some informed opinons first...
A few months back, I had a posi and 4.10 gears installed on my 98 auto. When the shop went to install them, I was informed that one of the axle bearings had spun, but the mechanic was 99% positive that he could fix the bearing and make it usable again. This shop does nothing but rear ends, so I trusted the guy. For two months I have been driving on the setup, and haven’t heard a single sound from the pumpkin back there.
Two days ago, I had my rear adjustable lower control arms put in by a professional mechanic. These are the Granatelli ones with the weight jacking system. They are also adjustable length-wise to accommodate moving the axle backward and forward. As such, this required that we measure the length of the old stocker LCA’s and adjust the length of the new ones to match.
Before the installation, the car would pull slightly to the right, but there is no tread wear going on up front at all. After the installation, the car seems to pull just a little more to the right, but almost to the point of not being any more detectable than before. Now that I have my rear seat out for the installation of functional side scoops, I can hear a noticeable whirring noise coming from the rear end, where like I said before, was quiet as a mouse.
Knowing that the car feels like it pulls a little more to the right, and now the new noise coming from the rear, do any of you think that the length on the right LCA should be lengthened just a bit?
Would a shorter LCA cause the driveshaft to be a fraction too long and compressed into the rear posi that this would cause some excess pressure on the unit, thereby resulting in the new noise?
I’m assuming that lengthening the right LCA would correct the extra pulling to the right as well, correct?
Associated with all the above concerns, I'm thinking that if the new LCA's werent' set exactly to the corresponding old LCA's, that the rear axle is now under a little stress being that it isn't perfectly straight. I didn't bother to take note of the where the axle connects to the pumpkin housing, so I'm thinking that the new angle that the axle connects to the rear, might be the cause for the noise. Yes, no?
Any thoughts or suggestions are appreciated!
