rear leaf springs
  • Thread starter Thread starter davestang67
  • Start date Start date Mar 10, 2009
D
davestang67
11
Marana, AZ
Mar 10, 2009
  • Mar 10, 2009
i want to improve the rear suspension of my 67 mustang. Is it worth re-arching the leaf springs or should i just buy new ones. Also how much of a performance handing difference would it be if i install a rear sway bar. i have a 1" sway bar in the front.
tx65coupe
Mar 10, 2009
  • Mar 10, 2009
I don't really care for rearching. It always seem like they begin to sag much more quickly.
New leafs don't cost that much. You could get springs for a GT or there are a few other performance springs available.
Upgrading the front sway bar and adding a rear one will help with handling.
Az Pete
711
18
49
Panama City, Fl.
Mar 10, 2009
  • Mar 10, 2009
Just buy new springs. Easier all the way around.
rbohm
6,698
550
204
tucson,az
Mar 10, 2009
  • Mar 10, 2009
+3 on buying new springs. while re arching springs can be cost effective, do so only if you are selling the car, or will drive it less than 50 miles per year or so. remember that you are dealing with 40 year old metal.
jst6
152
Tucson, AZ
Mar 10, 2009
  • Mar 10, 2009
+4 on new springs. you can get them with stock height +1" or -1" with as many as 5 leaves. Calvert Racing has a setup of a split mono leaf that works with thier traction bars. a friend of mine has those on his 67 Camaro RS that runs high 8's. He carries the front wheels 100 to 150 feet from the start line with that setup and the right tires.
H
htwheelz67
444
mission viejo ca.
Mar 10, 2009
  • Mar 10, 2009
check out flex a forms........
socalwrench
26
  • Mar 11, 2009
+4, buy new springs. keep your old ones if you want for originality. adding a rear sway bar will help keep the car more level during cornering. I would first add stiffer springs.
Shakin66
628
Waycross, Ga / Lake James, NC
Mar 12, 2009
  • Mar 12, 2009
It has been 3 years and my memory isnt that great but I think I used 4.5 leafs and was actually thinking to myself yesterday how much better the car handles. I have had 620#s and the 1" sway bar on the car for years but before the rear spring change the rear wouldnt stay planted like it does now. It will ride rougher though.
4tun8
172
Classified
Mar 12, 2009
  • Mar 12, 2009
New leaf springs are extremely cheap.
Leaf Spring Kit - $164.95
D
davestang67
11
Marana, AZ
Mar 14, 2009
#10
  • Mar 14, 2009
  • #10
thanks for advice. sounds like new ones is the way to go. i currently have 620 coils springs in the front with 1" sway bar.....it feels nice and solid but i need to compliment it with a solid rear end suspension!
68 coupe rear drop
  • Butchd88
  • Apr 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 19, 2026
C.R.M.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
