Rear lower control arms, help
Snikt89GT
264
Deland, Florida
Ok, hopefully i'm just a retard here. I'm trying to put in my rear lower control arms (finally after the new bolts showed up).
I put the chassis part in first, put the bolt on (not torqued). Then I put the spring on and started jacking it up into the axle part.
I got it to the point where it was even and where I should be able to slide the bolt through, but the hole doesn't line up at all??
Crappy quality pic, but you get the idea:
