Does this require pulling the motor? Because if it does, I'm thinking about just getting a new crate motor...one of those 5.0 strokers w/cams. Who sells modular crate motors with aftermarket cams installed already?
A rear main and oil pan can all be done in the car. The trans will have to come out for the rear main, you then need to jack up the enigne to get the clearence to pull out the oil pan or drop down the k-member a little bit to get the clearence.
