Im on my 3rd rear main seal on my turbo project.
First one I did worked which was my first time ever doing one. When my trans case cracked I sent the car to my mechanic to change the RMS thinking that was it. So he changes the seal and finds the crack in the trans case.
Anyways trans fixed and the new RMS leaked so I put another one in and this one is leaking now. After initial startup it leaked enough to put a small puddle on the ground dripping down the inside of the mcleud block plate. But after idling It doesn't drip. What the heck could the problem be. I lubed the heck out of it with oil before putting it in.
Anyone have any ideas. Or should I take the trans out again and put one of those felpro ones with the extra sleeve on it. Or finish the project and drive it around to see if there is indeed a big leak. Oil pressure was 30 at idle on cold startup FWIW.
Thanks in advance.
Dan.
Thanks in advance.
Dan.
