(you know I mean well)...my rear main seal leak got worse when I would take it to the track or go WOT on the streets...I HIGHLY doubt your going to actually blow it out...but my leak would get worse as the rpms climbed and for longer periods of time...it makes a nice smoke show when it gets on your clutch (slips/burns) and on the exhaust (burns off)...FastDriver said:Same thing in my case when I had a leaky rear main. Even if it's smoking that bad, though, he won't do any mechanical damage. I think that's his main concern.
5spd GT said:I consider clutch/flywheel mating (drivetrain - aka. mechanical) a possibility for mechanical damage. It really would be smarter to stay out of hard throttle until it is fixed assuming the leak is significant enough.
FastDriver said:Leaky rear main seals are common and though you should keep and eye on the oil level, you won't hurt anything by running the car.
FastDriver said:And you didn't notice any clutch slipping problems before you went to the track?
Mustang5L5 said:You can't really blow it out. The back of the flywheel almost buts right against it and the rear main is a pretty thick seal. It's in there tight.
With that said, every 5.0 engine i have ever removed has had a leaky rear main to some degree. Some dribble down never hit the ground, others make a few drops every time the car gets parked.
I've been into about 10 5.0s and always see at least a slight leak.FastDriver said:BS... Go run it. If your rear main seal was fully blown out, the engine oil would be pouring from your engine. Leady rear main seals are common and though you should keep and eye on the oil level, you won't hurt anything by running the car. To prove it, go put the car through it's paces a couple of times on a highway somewhere and nothing bad will happen.
Chris
....but both my stangs had leaking rear main seals that were dripping oil all over the clutch.
