rear main seal
well it depends on if you think pulling the tranny, clutch and flywheel a big deal. also, if its been leaking for awhile and its a 5spd, there is a good chance the flywheel needs resurfaced or replaced and needs a new clutch
If that's the only thing holding you back from getting an otherwise straight 86, I would say that the leaky seal is no biggie. It would give you an excuse to resurface the flywheel and throw in a new clutch, maybe even change cables, quadrant etc.
this is the ad for it and its canadian
86 gt
16" centerline stars
flowmaster mufflers
off-road H-pipe
fuel-injected 5.0L motor
sunroof
primer on red-interior
210,000kms
Aircared till next year
runs good
sony cd player
Needs some work
1400$obo
The other thing to be aware of is that when engine's produce too much crankcase pressure, or the pressure isn't vented properly (pcv system is malfunctioning) it will force oil out of seals and gaskets. Many a rear main seal has been replaced only to find that the new leaks also. Crankcase pressure will force oil out of a brand new seal.
I'm not saying there's nothing wrong with the seal. Just understand that a leaking seal doesn't necessarily mean that the seal is bad. High mileage engines with deteriorating ring seal and excessive blow by create excessive crankcase pressure. Clogged oil traps and pcv valves also can cause excessive crankcase pressure.
hissin - what's Carolina BBQ? you gotta come over this way; I'll treat you to some BBQ.
Yeah I have a leaking rear main seal. I've been driving it since the spring, and I haven't noticed any difference in performance when I drove it up and down the driveway last fall. But this fall/winter I will pull the engine out and fix that, and there is a good chance of putting in a 331 Stroker. If not the stroker, maybe turn it into a 306, or at the least rebuild the 302. Be a great time to clean the engine bay, paint the engine, and all that good stuff!
Where is the PCV valves located?
