Rear Main Seal
  • Thread starter Thread starter kpack5982
  • Start date Start date Jun 4, 2009
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Jun 4, 2009
  • Jun 4, 2009
So i'm puttin my new clutch in and my rear main seal is leaking so I'm at the point now where everything is out, but I can't get the rms out. i tried a screwdriver, but i don't understand how to "pinch" it to get it out. Anyone have any ideas or tips?
4G-KDMP
935
CA
Jun 4, 2009
  • Jun 4, 2009
Have you tried running a screw through it and then pull it out?
Try to center the screw and don't got to deep toy don't want to scratch the end of the crank
kpack5982
Jul 13, 2005
325
Granger, IA
Jun 5, 2009
  • Jun 5, 2009
I tried a screw, but unfortunately it didn't work, but maybe the kind of screw i used wouldn't work. Like a self tapper? or drywall screw?
kpack5982
Jul 13, 2005
325
Granger, IA
Jun 5, 2009
  • Jun 5, 2009
all i have to do is remove the flywheel right, and the rms should be right there?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 5, 2009
  • Jun 5, 2009
A drywall screw shold be ideal.
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,057
224
Massachusetts
Jun 5, 2009
  • Jun 5, 2009
I just use a very thin flathead on the engine block side and it comes right out
ID89GT
1,659
18
49
Spokane Valley, WA
Jun 6, 2009
  • Jun 6, 2009
Thats what I did. And you will have that block plate you gotta take out also but it is pretty self explanatory once you get the flywheel off..
kpack5982
Jul 13, 2005
325
Granger, IA
Jun 7, 2009
  • Jun 7, 2009
man!!!! I still can't get it. Is there any metal in the seal cause all i can do is get the rubber on the outside off, but the rest of the seal won't come. Please someone help!!!!!!!!!!!!!
kpack5982
Jul 13, 2005
325
Granger, IA
Jun 7, 2009
  • Jun 7, 2009
do you really have to give it a hard pry to get it out?
TenorPlayinGuy
1,208
Canyon Country, Ca
Jun 7, 2009
#10
  • Jun 7, 2009
  • #10
Ideally you would use a seal puller to remove it as to not cause damage to the crank, or the machined cap. However I have had to use a rubber mallet and several screw drivers before. Sometimes your lucky and sometimes its a PIA! Safest way I believe is to attack it from the outside ring edge. Tap in then pry the screwdriver outward towards the side of the car. Takes some time im sure.
Aryan15
236
CA
Jun 7, 2009
#11
  • Jun 7, 2009
  • #11
I drilled 3 holes equally spaced around the seal and slide hammered it out. It helps if you have the new seal to know where to drill the holes.
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,057
224
Massachusetts
Jun 8, 2009
#12
  • Jun 8, 2009
  • #12
It is a stiff seal. It's not soft like you'd think.
kpack5982
Jul 13, 2005
325
Granger, IA
Jun 8, 2009
#13
  • Jun 8, 2009
  • #13
Yeah, it was pretty stiff, but eventually a buddy of mine came over and helped out. Apparently the screwdrivers I had just didn't seem strong enough, but he had a nice hard flathead that eventually worked. But it was quite the pain. Thanks for all the help!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 8, 2009
#14
  • Jun 8, 2009
  • #14
kpack5982 said:
Yeah, it was pretty stiff, but a buddy of mine had a nice hard flathead that worked.
Contemplating a CT
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jun 8, 2009
#15
  • Jun 8, 2009
  • #15
CT applied. Carry on with the Tech.
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,057
224
Massachusetts
Jun 8, 2009
#16
  • Jun 8, 2009
  • #16
Lol. good stuff
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Jun 8, 2009
#17
  • Jun 8, 2009
  • #17
sounds like you guys are a team
kpack5982
Jul 13, 2005
325
Granger, IA
Jun 8, 2009
#18
  • Jun 8, 2009
  • #18
lol, that's hilarious!!!
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
