  • 1994 - 1995 Specific Tech
rear main
  • Thread starter Thread starter donnie84
  • Start date Start date Oct 2, 2004
D
donnie84
52
  • Oct 2, 2004
how much am i lookin at spending to replace a rear main seal in my 1995 gt? i know its a cheap part but how much for labor n such should i expect to pay
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 2, 2004
  • Oct 2, 2004
Depends on the labor rate of the shop. It's probably an hour and a half job.
D
donnie84
52
  • Oct 2, 2004
i have heard ppl saying that it is a 10 hour job, he said hed need it for the day. thanks for you support guys!
194stang
148
  • Oct 2, 2004
i dont think you could do that in a hour and a half....the tranny has to come out.bellhousing,clutch, flywheel, the oil pan has to be droped.... when i replaced mine,i just went ahead and pulled the motor, wasnt that much more work
S/CBlack95GT
2,018
Tampa Palms, FL
Oct 2, 2004
  • Oct 2, 2004
I bet most places will charge at least 3 hours, which would be around $150.
Killercanary
The car that set the bar.
Altoona, PA
Oct 2, 2004
  • Oct 2, 2004
The oil pan does nopt need to be removed. I could have it done in 3hrs on my own car. I just replaced mine with a fel pro telflon lined one, we'll see how it holds up.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 2, 2004
  • Oct 2, 2004
Why would you need to remove the oil pan? The rear main seal seals the back of the crankshaft to the block. The oil pan has nothing to do with it.
Figure at least 3 hours, like said earlier. The driveshaft, transmission, starter, bellhousing, pressure plate, clutch disc & flywheel all need to be removed.
While they are replacing the rear main seal, have them replace the pilot bearing, clutch disc, throw out bearing & resurface the flywheel. They are not absolutely necessary, but you might as well since they are taking them all out. They won't charge you any more labor as well (except $20-$30 to resurface the flywheel). Those are the "moving" parts of the system, and you don't want to pay a mechanic another 3 hours of labor just to replace a TOB or pilot bearing.
Scott
D
donnie84
52
  • Oct 3, 2004
actually now that you mention it, my throw out bearing is making one helluva sound so i was plannin on jsut replacing the whole clutch with a frpp king cobra so it can handle the extra ponies from either a h/c/i or a vortech in the future. i would also have them resurface the flywheel if i had them replace the clutch. Are you sure about the oil pan? my mechanic said that he would have to remove and replace that as well? he said he would need it for the whole day, and others have told me numbers in excess of 750 dollars to replace just the rear main.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 3, 2004
  • Oct 3, 2004
You don't need to remove the oil pan at all. I have friends that work at ford and the tranny guy replaced my clutch and while I was there he told me my rear main was leaking. I bought one right then and there and he said it just popes out and put the new one in. $750 No way just for the rear main seal. You should get another quote from another shop IMO.
D
donnie84
52
#10
  • Oct 3, 2004
  • #10
yea thast what i thought i thought i mean its a 20 dollar seal, and i dont see why it would take sooo long. im ognna get some other quotes... tanks guys! any other commets please feel free.
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
