Rear Seal on a 4 Speed Top Loader
Pbum5
515
Minneapolis, MN
Have a little leak at the back of my Tranny.
Just wondering if the rear seal on a Top Loader can be replaced without having to take the tranny apart? Can it be replaced while in the car?
What oil should be run in a Top Loader, same as the rear Diff?
Thanks.
Yea, you can change the rear seal on a Toploader without dissassembly. If it's a small block Toloader, the seal is the same one used in the C-4's. Just pull the driveshaft and then the seal. Toploaders use gear oil. Something like 85W-90 or 140. Fill thru the plug on the right side and till it just starts to run out the hole.
thanks. that's what I needed to know.
