rear shock swap help
i just got my new strange 10 way adjustable shocks for the rear and i went out to see if i could pull off the ones that are on there. when i tried to loosen the bolt, the upper part of the shock just spins with it. i tried to hold it and have someone else loosen the bolt but i cant get a grip on the upper part of the shock. what is the best way to do this? also, is there a torque setting for the upper or lower bolts?
maybe a cloth/nylon oil filter wrench could sinch tight enough to get a grip on top of shock? don't forget to use some liquid wrench to help lossen the rust. if you can get a oxy/acetelene torch on it you could burn the nut off. maybe a small grinder with a zip cut blade on it would also work. you mayhave to take some interior panels off.
Jerry nailed it. i have no idea why i didnt think of that. i went out just now, filled the compressor and it took those nuts off:rlaugh: its too dark to work on it now and without the relay for my electric fan i ordered today i have no car anyways so ill finish the shocks tomorrow after work. thanks guys
