rear shocks and spring
  • Thread starter Thread starter STP72
  • Start date Start date Apr 19, 2008
STP72
109
  • Apr 19, 2008
Anyone have a HOW - TO for changing rear shocks and springs on a 88LX
Thanks
the pony boy
358
Apr 20, 2008
  • Apr 20, 2008
rears are easy.its really just a remove and install thing.have the rear of the car on jack stands remove the nut that holds the shock in place.(trunk on notches in the hatch are on lx's/gt's).support the rear so it doesnt drop hard and let it lower as far as it will go.you can remove the quads to get more room and the spring should fall out and when it does un bolt the shock from the bottom and its out.than putting them in is just as easy.the fronts thats another story. do a search theres alot of info on here about this. phil
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,119
224
Massachusetts
Apr 20, 2008
  • Apr 20, 2008
Yup, what he said. Rears are simple.
When i do springs, i remove the rear swap bar. I put the read body on jackstands and support the center pumpkin with the jack. I then unbolt the quad shocks and main shocks (or in your case take the main shocks off). Then i put some blocks under one side of the axle and lower the other side down and you can take the spring out by hand. Jack the axle back up, put some blocks under that side and then lower the other side down and change the spring. Then jack the axle up even and rebolt the quad shocks on and then install the main shocks
1-2 hour job
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 20, 2008
  • Apr 20, 2008
Just make sure the pigtail on the springs are to the rear of the car and pointing at the drivers side.
Ebay Lowering springs
  • Canyonred86
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
Habu135
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Suspension Quad shocks
  • keel
  • May 20, 2026
Fox 5.0 Mustang Tech Sep 2, 2026
AeroCoupe
