What i would do is pop the hatch and right around the wheel hump there should be a trim panel access and poss. a rubber cap. and there should be 13mm or 14mm nut just loosing the nut up. rasie adn support the car how you can and take the lower shock bolt out of one side and then take the top nut off and remove old shock and reverse procedure
