Rear sneak peak
  • Thread starter Thread starter srtthis
  • Start date Start date Mar 17, 2013
  • 3
First Prev 2 of 3 Next Last
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 25, 2013
#21
  • Mar 25, 2013
  • #21
^^ IMHO getting the old bushings and cups out are more difficult that putting the sphericals in. either way not a very difficult job
CarMichael Angelo
8,909
234
Birmingham, al
Mar 25, 2013
#22
  • Mar 25, 2013
  • #22
RacEoHolic330 said:
Looks good man. I think madmike1157 has some left over worm clamps he can lend you to strap those brake lines to the axle tubes
I do just happen to have 4 slightly used, modestly ridiculed 3" worm gear clamps for just that purpose,.....give me his address and I'll send them to him.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Mar 25, 2013
#23
  • Mar 25, 2013
  • #23
I wouldnt redo those lines, just strap em down
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Mar 25, 2013
#24
  • Mar 25, 2013
  • #24
MikeH686 said:
srtthis are those spherical bushings by chance were they difficult to install
my uppers are solid in the housing. im using UPR radius arm uppers which have a heim joint on each end. took about 5 minutes to get the old bushing out with an air hammer and a dull bit.
Reactions: Sharad
MikeH686
Mine is only two inches though.
2,843
1,753
184
Waldorf, MD
Mar 25, 2013
#25
  • Mar 25, 2013
  • #25
OK yeah I'm going with Upr double adjustable with spherical in the housing
Reactions: stangboy and Sharad
srtthis
5,129
1,666
204
Maryland
Mar 25, 2013
#26
  • Mar 25, 2013
  • #26
if you have an air hammer its pretty easy to get the old stuff out. i used a really dull chisle bit and just beat it out.
MikeH686
2,843
1,753
184
Waldorf, MD
Mar 25, 2013
#27
  • Mar 25, 2013
  • #27
I'm sure I can find one
srtthis
5,129
1,666
204
Maryland
Mar 25, 2013
#28
  • Mar 25, 2013
  • #28
if not a corded drill with a bunch of cheap drill bits work. just punch a bunch of holes in the rubber till you can knock the center out. the beat the cup down with a hammer and knock it out.
MikeH686
2,843
1,753
184
Waldorf, MD
Mar 25, 2013
#29
  • Mar 25, 2013
  • #29
Now what would be involved in putting the new bushings in just slide them in or do thy need to be pressed in
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 25, 2013
#30
  • Mar 25, 2013
  • #30
They more of less slide it with a threaded retaining nut holding them in place. I always locktite the threads, btw.
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Mar 25, 2013
#31
  • Mar 25, 2013
  • #31
Put them in the freezer the night before you install them. Then take them out right before you slide them in. They'll shrink a little that way.
srtthis
5,129
1,666
204
Maryland
Mar 26, 2013
#32
  • Mar 26, 2013
  • #32
yup i did that with these bushings also... they went in really easy
stangboy
3,932
469
194
New Orleans, LA
Mar 26, 2013
#33
  • Mar 26, 2013
  • #33
Me too
Reactions: Sharad
MikeH686
2,843
1,753
184
Waldorf, MD
Mar 26, 2013
#34
  • Mar 26, 2013
  • #34
Sweet wanna be bestest buds stangboy
Reactions: 84Ttop
hsean
656
69
69
dearborn,michigan
Mar 26, 2013
#35
  • Mar 26, 2013
  • #35
srtthis said:
not exactly... they are stainless hard lines. double flaring stainless isnt all that easy. you need to heat it up so it doesnt crack
my friend did mine and no cracks and he did the double flares on both sides i have a problem though i have the exact same set up as you with the rear end mine came out of a 95 gt .i went with stainless fuel and brake lines as well i have the 1987-93 brake lines and i need to mate the one main line .what fitting did you uses i am thinking 7/16 female fitting on one end to 3/16 male fitting on the other?i don't want to confuse anyone if you look at the rear end where they meet in the center that brake hose goes to the top .i need a compression fitting or something similar any ideas autozone and oreilys didn't have anything close.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 26, 2013
#36
  • Mar 26, 2013
  • #36
Nice....now try not to break this one, would ya!
stangboy
3,932
469
194
New Orleans, LA
Mar 27, 2013
#37
  • Mar 27, 2013
  • #37
srtthis
5,129
1,666
204
Maryland
Mar 27, 2013
#38
  • Mar 27, 2013
  • #38
my center hose is for a standard V8 87-93 car
my end hoses are for an 85-86 SVO. all the fittings are as they came from ford.
hsean
656
69
69
dearborn,michigan
Mar 27, 2013
#39
  • Mar 27, 2013
  • #39
mine are different being a 95 rear end and 87-93 lines
srtthis
5,129
1,666
204
Maryland
Mar 27, 2013
#40
  • Mar 27, 2013
  • #40
Ah ok...
Don't you just hate when your moving along nicely and find you don't have everything you need... Line brake fluid
  • 3
A
90 Fox 4Lug rear convert to 5 Lug
  • adimice
  • Jun 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
limp
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Rear mounted battery distribution blocks?
  • 387lx
  • Mar 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
JD1964
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
