Rear Suspension Clunking
  • Thread starter Thread starter WldstrawbryLX
  • Start date Start date Dec 31, 2005
W
WldstrawbryLX
35
Everett,WA
Dec 31, 2005
  • Dec 31, 2005
Got this annoying clunk on the LR side. I've tried to wiggle the shocks, lugnuts r tight. Has anyone else had this problem?? Presently I have those Sensa Trac shocks (not my choice). They seem to be tight. Its almost a constant noise except when I'm on really smooth pavement. Anyone??
NKau
1,346
Jefferson, WI
Dec 31, 2005
  • Dec 31, 2005
Take a look at both ends of the upper and lower control arms. Bushings might be trashed, or you may have some structural damage in your torque boxes where the control arms connect.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Dec 31, 2005
  • Dec 31, 2005
I had that issue on my car under hard launches and even on the street right before I found the issue. Turns out my shock was blown, but I couldnt tell until I unbolted it, and pushed on the bottem of it. It sucked up and stayed there... Put another shock we had in, and it hasent made any noises since!
The control arms are also another place that might be causing the noise!
W
WldstrawbryLX
35
Everett,WA
Dec 31, 2005
  • Dec 31, 2005
Cool,thanks. At least it gives me a place to start.
marine_2003
427
Lake County, FL
Jan 1, 2006
  • Jan 1, 2006
I had the same problem on my 85, one of the reasons was because my control arm bushings were about gone. Also the u-joints in my driveshaft needed to be replaced.
M
Mike92GT
583
Florida
Jan 1, 2006
  • Jan 1, 2006
also take a close look at your exhaust, mainly the tail pipes. Check that they are not rubbing or hitting anything. Common places they can hit are the front of the axle tube, gas tank, upper control arms, rear sway bar, floor pan, etc. You could also try going through and making sure all the bolts in the rear suspension are tight, and check all the bushings
bubba-dough
1,044
Indiana
Jan 1, 2006
  • Jan 1, 2006
Upper/lower control arms, any of the control arm bushings, could be the spring or spring insulator, check for structural damage around torque boxes, take the shocks off and check them, could possibly be in the rearend. Basically anything in the rear could cause that problem.
W
wazazzle
618
In the dumpster behind McDonalds. WA
Feb 2, 2006
  • Feb 2, 2006
I actually had the same problem but on my pssgr rear. At first I checked to make sure everything was tight and not moving by hand. About week later as I was installing new shocks and springs. I found the culprit!!! Turned out to be the bottom bolt that held the shock had 5 threads sheard off all around. No way to tell just by looking at it. Just a few threads was enough to make a noticable konk sound. I replaced it and no more noise.
Euphoric306
905
  • Feb 2, 2006
hehe the guy i bought my car from sid i had performance shocks and struts on there... they said sensatrac on them and since i didnt know anything about suspension back then i thought he was telling the truth.... i walk into my local brake-masters and see this ad for monroe sensa-trac shocks/struts and i go ...stupid, stupid car
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Feb 2, 2006
#10
  • Feb 2, 2006
  • #10
Don't know if its related but i've had that problem twice on my explorer, once was with a bushing going out, then a couple of months later a shock was busted.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
2015 Ecoboost premium performance pack
  • matthewt
  • Jul 30, 2024
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 21, 2024
89ripper
