  • SN95 4.6L Mustang Tech
Rear Suspension Squeaking
  • Thread starter Thread starter va01gtstang
  • Start date Start date Nov 30, 2006
va01gtstang
61
  • Nov 30, 2006
I already tried searching but didn't find much besides that it might be my wheel bearings squeaking. My rear suspension has constant squeak/creak everytime I drive. Especially if I have a passenger. I've pushed down on the trunk to see if it makes the noise and it does. Could it be my shocks or lower control arms? I have stock control arms and I Monroe Sensatrak shocks. Any help or advice?
BennyBlown2v
1,233
Carmel, INdiana
Dec 1, 2006
  • Dec 1, 2006
Upper control arm bushings are usually the first thing to go, and one of the worst sounding too.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Dec 1, 2006
  • Dec 1, 2006
My stang did the same thing after the first summer i bought it.On mine it was the lower control arm bushings,where the lower control arm goes into the chassis(torque box).Everytime it would have suspension travel...it would squick,or if i got in or out of the car...it would squick.So what i did to solve the problem,is sprayed some WD 40 in that area to stop it,and it did.Maybe this is the same issue you have.
When i installed my aftermarket rear control arms,i lubed the hell out of them before i installed them just for this reason.
va01gtstang
61
  • Dec 1, 2006
thanks for help. I was kinda thinking it would be the upper or lower control arm bushings.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 1, 2006
  • Dec 1, 2006
Blast everything down with silicone spray as WD-40 will degrade your rubber bushings...
BennyBlown2v
1,233
Carmel, INdiana
Dec 1, 2006
  • Dec 1, 2006
So will just rain water, or air for that matter But yeah, silicone over WD in this case. Idealy you should take the control arm off and grease it with either lithium (wont last as long, might eat away at the rubber) or teflon based grease (goooood stuff, but expensive).
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
