Rear Suspension
spool, 31 or 33 spline axles, c clip eliminators/9" ends, some type of control arms with solid bushings all teh way around (wolfe, team z etc) stock springs, anti roll bar and 50/50s and some tire
The Team Z rear suspension looks sweet.
Killer price too.
What kinda rear coil overs should I look at? Need something that can be run with Lakewood 50/50s.
In the front should I just run some normal lowering springs? What kinda shocks?
Hey Rick... How well would that kit perform for a street driver that wanted to turn inside of a beamer on a tight corner?
(referring only to the rear end setup at this point)
Killer price too.
Front - COIL OVERS using anybodies kit, Strange Adj Struts
Rear- If you go with the Tema Z Kit ask Dave about the Strange coilovers. A True coil over will not work with a Lakewood shock, they do sell kits to put a coil over in the stock location.
Dagger- I'm going to try to talk to Dave tonight I'll let you know ;) I do have a set of special Metco lower arms that I am going to sell. They have 5 1/4 mile passes on them..lol then the car was taken apart, perfect shape, Delrin bushings, etc...
Damn, if i would have known about Team Z Motorsports rear lower control arms, at a price like that.. i would have bought them over the MM arms i bought. Looks like a heim joint on one end, and a spherical bushing on the other? Can't get much better!
Kicking myself now...
Rick 91GT said:
I just got off the phone with Dave, he would not reccomend his kit for a road race/cornering set-up, it would have a lot of body roll. His kit is set up to go straight and fast.... :nice:
Copy that Rick. Thanks for checking on it. :)
Is the Team Z motorsports kit street friendly for a daily driver or only good for a drag only car? I dont care about cornering at high speeds just want it to be safe. Also what kind of 60's are you guys pulling with that setup on what kind of tires?
