  • SN95 4.6L Mustang Tech
rear swaybar hitting exhaust
  • Thread starter Thread starter Dave Holman
  • Start date Start date Dec 27, 2005
D
Dave Holman
72
  • Dec 27, 2005
My rear swaybar sits only about an inch below my exhaust pipes. When I hit a bump sometimes I can hear the swaybar bang into the exhaust pipes. I have been able to minimize this by adjusting the position of the exhaust pipes but I have not been able to completely eliminate it.
Has anyone else had this problem or come up with a fix for it?
sgarlic
3,085
Dec 27, 2005
  • Dec 27, 2005
I haven't had that exact problem, but I am sure you could go to an exhaust shop, and have them fab up a bent piece to fit in there for more clearance.
trailblazr81
571
Hollister, Cali
Dec 27, 2005
  • Dec 27, 2005
I havent had the sway bar hit the pipes... but I can see where the axle has hit the pipes.
back_in_black
460
frederick, MD
Dec 27, 2005
  • Dec 27, 2005
I have the magnaflow catback and experienced the same thing, I had the exhaust shop dent in the exhaust tube a little where it was hitting
elite130
149
Denver, CO
Dec 27, 2005
  • Dec 27, 2005
I have the same problem. I need to get under the car and see if I can adjust it a little more.
Jamessocal
48
San Diego, CA
Dec 27, 2005
  • Dec 27, 2005
I had the same problem when I had my Magnaflow. I got it to the point where it would only hit on large bumps, but it got to the point where it would loosen the tips after a while.
Annoyed me so much I got rid of it and got the Steeda catback. No more problems now.
40th GT
916
Lawrenceville, GA
Dec 27, 2005
  • Dec 27, 2005
I have the same problems with my Magnapack catback. I just learned to deal with the noise I tighten the tips once in a blue moon.
D
Dave Holman
72
  • Dec 27, 2005
At least I know I'm not the only one with this problem. I'm thinking maybe I can remove the tailpipes, bend them slightly, reinstall them and hopefully have the clearance I need.
02LaserRed2V
379
Augusta, GA
Dec 27, 2005
  • Dec 27, 2005
It's a common problem with magnaflows. I had mine adjusted a little to where it only hits on large bumps. I've just learned to deal with it though it is annoying at times.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 27, 2005
#10
  • Dec 27, 2005
  • #10
Are you sure it's the Swaybar? usually the pipes hit the UCA's, Axles and/or Gas Tank Cover in the majority of the cases
either way best thing to do it get the pipes bent
02LaserRed2V
379
Augusta, GA
Dec 28, 2005
#11
  • Dec 28, 2005
  • #11
Mine (driver's side) sat too close to the gas tank as well. I finally had that fixed, but the tip is now too close to the rear bumper. Now I'm getting smoke on the cutout! Since the tips are already welded, I might just get another catback.
back_in_black
460
frederick, MD
Dec 28, 2005
#12
  • Dec 28, 2005
  • #12
mine was definitly hitting the sway bar there was a mark on it.
D
Dave Holman
72
#13
  • Dec 28, 2005
  • #13
Mine was definitely hitting the sway bar. I just installed a new set of Steeda swaybars and I could see the mark where is was rubbing on the old swaybar.
D
Dragstr05
643
Stafford VA
Dec 28, 2005
#14
  • Dec 28, 2005
  • #14
My catback hits the gas tank cover. Not really any problems anywhere else, but the way the flowmaster kit is made doesnt exactly allow for any good adjustments. Its one long pipe from the muffler outlet all the way to the tip, and you can only move the entire piece, which either makes it rest on something (ZERO clearance), or you give it clearance an the tip just looks like **** because it doesnt come out even through the cutouts.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 8:58 PM
AlexM556
A
