Rear Upper control arms?
  • Thread starter Thread starter DemonGT
  • Start date Start date Mar 31, 2006
DemonGT
871
51
49
Sparta,WI
Mar 31, 2006
  • Mar 31, 2006
iv had the Pro3i weight jacker lower arms for some time now but still have the stock uppers...i get bad wheel hop if i spin the tires....not sure if new uppers will help or not but i figure they need replacing anyway...but is there a certain kind i should go with? was looking at the matching pro3i uppers but they seem pretty spendy?
Brads Coupe
Sweeeeet!!!
2,838
Calgary , Alberta, Canada
Mar 31, 2006
  • Mar 31, 2006
I just purchased a set of these. Very affordable.
06stangtyme
21
Nashville
Apr 1, 2006
  • Apr 1, 2006
I feel the best sollution to get rid of wheel hop is to
replace the rear shocks, The stock shocks are weak IMO.
DemonGT
871
51
49
Sparta,WI
Apr 1, 2006
  • Apr 1, 2006
those control arms look really nice..but i was steering away from the adjustable ones ...cause im a idiot and have/wouldnt have any idea how to set them..just wanted some to bolt in and go...
also..the rear shocks arnt stock there the lakewood 50/50's, only a couple hundred miles on them
1991GreeNLX
129
Houston TX
Apr 1, 2006
  • Apr 1, 2006
jut buy SVO upper control arms they are like $85.00 shipped
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 1, 2006
  • Apr 1, 2006
Make sure your Quad Shocks are in place too!
Cougar5.O
87
Manchester NH
Apr 1, 2006
  • Apr 1, 2006
My thought exactly.
DemonGT
871
51
49
Sparta,WI
Apr 2, 2006
  • Apr 2, 2006
i removed the quads to fit my Nitto's..not to mention one was slit open and the other side the bracket thats bolted to the body to hold the quad was broke....and i was going to just flip them but after coming across those problums i just trashed them...and i havnt seen anywhere, where you can get factory style quads..there usually the KYB type and i didnt think it would work to flip them?
skip nay
110
Chambersburg Pa
Apr 2, 2006
  • Apr 2, 2006
I agree but you will like something that is adjustable so you can soften them up.
9
90bronconate
124
Phoenix, AZ
Apr 2, 2006
#10
  • Apr 2, 2006
  • #10
deffinitely get the adj uppers so you can set your pinion angle. there's an article on hardcore50 that explains why pinion angle is important, i just can't seem to find it.
DemonGT
871
51
49
Sparta,WI
Apr 3, 2006
#11
  • Apr 3, 2006
  • #11
but i would have no idea where to set them at
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
M
1972 Mustang Upper Control Arm
  • Mustang Don
  • Dec 27, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jan 2, 2025
Realmongo
R
Rear Upper Control Arm Pivot Point
  • Rcdgl
  • May 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2025
Rcdgl
R
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
