  • 1994 - 1995 Specific Tech
Rear upper control arms...
  • Thread starter Thread starter johnny_munyak
  • Start date Start date May 17, 2010
J
johnny_munyak
97
  • May 17, 2010
Have a chance to pickup some Edelbrock rear upper control arms for a decent price. Was wondering if they are a good improvment over stock.
How do you go about setting them up properly?
Tanus
847
A to the Z
May 17, 2010
  • May 17, 2010
yeah, I think the new bushings in the arms that make the biggest difference.
the solid tubular ones just get bolted in, are they the double adjustable ones?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 17, 2010
  • May 17, 2010
If this is a street car I would pass and just install new rubber bushings in the stockers.
maximummotorsports.com said:
We performed extensive testing of rear upper control arm bushing materials during the development of our Panhard Bar. When retaining the original four-link suspension, the best compromise between resistance to suspension bind, best control of axle position, best ride quality, and least potential damage to the chassis, is to retain rubber bushings in the rear upper control arms. This is especially important when adding a Panhard Bar. The compliance of a rubber-bushed upper control arm is required when a Panhard bar is added to the Mustang four-link suspension.
J
johnny_munyak
97
  • May 17, 2010
Yes. They are the double ajustable with urethane bushings.
Edelbrock Adjustable Upper Rear Control Arms - JEGS
This is primarily a street car.
J
johnny_munyak
97
  • May 17, 2010
Thanks for the help. I`ll pass and look into the stiffer bushings as per Maximum motorsports.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 17, 2010
  • May 17, 2010
It's a lot more work to replace the stock ones, and costs the same as just buying new control arms.
Kurt
Tanus
847
A to the Z
May 17, 2010
  • May 17, 2010
with the double adj you need to get an angle finder with magnetic base, then you set the rear at -2(street) to-4 (race) degrees in relation to the driveshaft. I set mine to -3
J
johnny_munyak
97
  • May 18, 2010
So what if you are not intending on installing a panhard bar from Maximum Motorsports? They don't mention anything about installing them if not using a panhard bar?
Are the rear upper control arms hard to install?
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 18, 2010
  • May 18, 2010
Changing the upper and control arms is very straight forward. It's 4 bolts, 18mm heads.
Kurt
Dino Dino Bambino
1,672
89
79
Cyprus
May 18, 2010
#10
  • May 18, 2010
  • #10
I have the same ones and I love 'em. Combined with MM lowers, suspension bind during hard cornering is almost eliminated and the rear tires stay planted on the road.
Definitely good for the street especially if you like corner carving, and overkill for the strip where you're only going in a straight line.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
May 19, 2010
#11
  • May 19, 2010
  • #11
There testing on the bushing were during the development of their panhard bar.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
R
Rear Upper Control Arm Pivot Point
  • Rcdgl
  • May 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2025
Rcdgl
R
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Suspension Rear pinion angle
  • JD1964
  • Apr 30, 2025
Fox 5.0 Mustang Tech May 5, 2025
JD1964
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
