Rear Window Defroster And Tint ?
  • Thread starter Thread starter SF Lex
  • Start date Start date Mar 13, 2016
SF Lex
Advanced Member
Mar 8, 2016
230
125
73
CoCo County, California
Mar 13, 2016
  • Mar 13, 2016
Wondering if anyone has upgraded and added a window defroster in the rear of their foxbody hatchback ? Mines came with what maybe factory tint ? Although it has no defroster, so i must add it. Anyone have any experience on this ? I wonder if the window tint people do both ? Tint, and add a defroster ? Or will i have to do the defroster myself, or get it done when i have them remove the tint ?
View media item 12327
1990slow50H
66
27
38
Spring Lake MI
Mar 13, 2016
  • Mar 13, 2016
Might be easier to find a used hatch with a defroster and switch hatches, I'm no expert but I think my hatch has defroster..........that's never been used
Reactions: SF Lex
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Mar 13, 2016
  • Mar 13, 2016
Usually, you want one or the other Aftermarket tint is applied on top of the defroster. Defroster cooks tint. Cooked tint and removing cooked tint takes out defroster grid.
Factory tinted glass may be in the glass, so the defroster will not cook the plastic tint. Good luck.
Reactions: Davedacarpainter, SF Lex and jrichker
SF Lex
Advanced Member
Mar 8, 2016
230
125
73
Mar 13, 2016
  • Mar 13, 2016
Wow, thanks for that info. I need to do more research, wonder if they even made windows with defroster for 92 hatchbacks. Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,389
18,129
224
Massachusetts
Mar 14, 2016
  • Mar 14, 2016
Of course they do, and pretty much any 87-93 rear window will work...possibly even older.
Up in the northern states, defroster was common. Here in MA, I don't think I've ever seen a Fox without defrost. I'd almost call it rare.
No such thing as factory tinted glass for the Fox mustang. That implies a dark tinted glass similar to what you see on a an SUV. The glass on the fox is not perfectly clear though due to the imperfections in the glass, so there is always a slight, slight tint. But pretty much there are ONLY two windows for the fox mustang. With defroster grid lines, and without it.
If you want rear defrost, find a rear window and swap it ino your hatch. Plug it in, plug in a switch and you should be good to go. Just keep in mind aftermarket tint, when removed, tends to rip up the defrost grid lines. Hard ot get it off cleanly, so keep this in mind when searching used glass
Reactions: SF Lex
7991LXnSHO
7,387
2,746
194
Kearney, NE
Mar 14, 2016
  • Mar 14, 2016
I should specify the roll up plastic that you spray soapy water on to apply and cut around the edges is what easily bakes. I hope the pro applied stuff is better, because my 91 came with both, and I am using the defrost grid very sparingly.
When DIY tint was first big, I sold a lot of defroster grid repair paint. It was in a fingernail polish (or smaller) bottle. You taped on both sides of the grid strip with masking tape, and painted the missing or damaged spots back in with this metallic paint.
If you find a hatch to swap, (easier than just the glass?) this stuff may need a little of this grid repair paint. 3M and Permatex are brands I would ask for.
Reactions: SF Lex
1990slow50H
66
27
38
Spring Lake MI
Mar 14, 2016
  • Mar 14, 2016
oh by the way I really like the color combo, looks like the cars in good condition
Reactions: SF Lex
SF Lex
Advanced Member
Mar 8, 2016
230
125
73
Mar 14, 2016
  • Mar 14, 2016
Right on 1990slow50H. Someone did, and i took it off their hands when the transmission went out. Plus a divorce and ect. Now i get to pass the 100K miles marker on it, and remake it my own. Thanks.
7991LXnSHO
7,387
2,746
194
Kearney, NE
Mar 20, 2016
  • Mar 20, 2016
Cool or fubar, I wonder if any bubble glass Capri's had a defroster. It might cost a mint to buy a good used one, but those were a neat variation on the platform.
Reactions: SF Lex
7991LXnSHO
7,387
2,746
194
Kearney, NE
Mar 20, 2016
#10
  • Mar 20, 2016
  • #10
Look at your picture!
I think you forgot to shut off the pump and pay the last time fulfilled up. Or your car is being attacked by the deadly gas snake.
Reactions: SF Lex
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
Rear Window Louvers Hatchback
  • MDrisc
  • Mar 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2025
General karthief
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
