Y YoungStanger New Member Jun 29, 2005 11 0 0 Jul 28, 2005 #1 Jul 28, 2005 #1 How would you clean the rear window or clean out the louvers if it had an open scoop? Since the louvers are bolted on this would be a problem?
cleveland Founding Member Feb 19, 2002 579 0 0 SF>... Jul 28, 2005 #2 Jul 28, 2005 #2 YoungStanger said: How would you clean the rear window or clean out the louvers if it had an open scoop? Since the louvers are bolted on this would be a problem? Click to expand... Rear Window or 1/4 Windows? If you are refering to the actual rear windows you can lift them to clean the glass. They are hinged, I believe, and easy to deal with. -Dan
bigcat start with the upper hole, and if more traction is May 1, 2005 3,015 1 79 7200 feet Jul 28, 2005 #3 Jul 28, 2005 #3 yeah, i was reading up on them, and they are hinged, just so you can clean the glass.....
