Rear Window Replacement
  • Thread starter Thread starter 22Stang
  • Start date Start date Oct 8, 2004
22Stang
26
Bay Area, CA
Oct 8, 2004
  • Oct 8, 2004
My Passenger Rear window shattered on my 92 LX 5.0.
I got on another one on its way, just had a question for you guys who have replaced this window.
How should I go about replacing this window? What tools/other equipment might I need for this job?
Any info would help greatly.
DTT92LX
185
Downingtown, PA
Oct 8, 2004
  • Oct 8, 2004
Do a search on quarter window. Should be plenty of threads to lead you in the right direction.
UMDSmith
226
Salisbury, Maryland
Oct 8, 2004
  • Oct 8, 2004
You need:
9mm socket + wrench
a tool to clean of the butly tape used by ford to seal the window in. Don't worry, if its the seal from the factory, it will be crumbling by now.
A tube of windshield urethane
Some black metal primer, or whatever color.
A razor knife (preferably the long handled ones "long knife")
A LOT OF TIME
Okay, here are the steps. First, vacuum up all the glass you see, because even tempered glass will still cut you, and pokes like a bitch.
Then, remove the rear inside large plastic 1/4 panel. (have fun with this one)
Once removed, you should see a bunch of 9mm brass looking nuts that follow the perimeter of the window. Undo them all and save the nuts.
Once they are all out, take your razor knife (be careful here) and insert the blade in between the body and the remaining rubber trim of the glass, and lightly pull it along the perimeter. This is to cut the butyl tape. (Try pushing the window frame first, it may just pull right out.)
Now, once the window is out, clean off ALL the leftover crap, as much as you can. Take it down to bare metal if you need to. Once clean, PRIME PRIME PRIME any scratch marks. This will prevent rust, and trust me, it will rust if you miss a spot.
Prep the new glass. The bead of glue will be run right where the old butyl tape was, so you can see where it will hit on the glass. Prep the glass with some rubbing alcohol (we use a special solvent, but alcohol works) along the line where the glue will hit and let it dry.
Run a bead of the urethane. DO NOT run it any thicker then your middle finger, as you will just have a huge mess. For that window, a bead about the size of your pinky the whole way around will do.
Push the window in, it lines right up as the threads line up with the holes on the car. Once it is in and slightly pushed down, Start rebolting the window to the car. Torque them evenly, like you would changing a tire.
No high pressure car washes for 24 hours afterward, just to allow the glue to fully set.
Any other questions, feel free to PM me. I'm an autoglass tech if you couldn't tell.
22Stang
26
Bay Area, CA
Oct 12, 2004
  • Oct 12, 2004
sweet thanks for the info this will help tons.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Rear window failure
  • Moondog2178
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
Moondog2178
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
