  • 1994 - 1995 Specific Tech
rearend help
  • Thread starter Thread starter chief44
  • Start date Start date Jan 20, 2007
C
chief44
50
Western PA
Jan 20, 2007
  • Jan 20, 2007
My Mustang is making a clunking sound. I first thought u-joints. I replaced those and still have the noise. I put the car up on jack stands and started it up. The noise is coming from the rearend twisting upward. Is the rearend the problem or is it the control arms. The car does have 230,000 miles on it. Still runs like a raped ape.
1TallMF
955
Montreal
Jan 20, 2007
  • Jan 20, 2007
When does it clunk? Is it when you're taking off after a stop or is it more over bumps? Or is it when you launch it hard? Are there any vibrations at speed?
I have some major deflection in my control arm bushings that causes a clunk over bumps and the driveshaft to hit the floor when I launch it (soon to be R&R'd). If the car has that many miles and you are still running stock arms and bushings, its high time you change those out, they're likely all cracked and rotted. If the gears were worn bad enough to clunk, I would think that it would be accompanied by lots of other noises like whining and vibrations. Only other things to check would be to make sure the sway bar is in good shape and the bolts are tight, and the shock mounts are tight as well.
C
chief44
50
Western PA
Jan 20, 2007
  • Jan 20, 2007
the rear sway bar in a new steeda piece i bought last year cause the stock piece broke. I can actually see the rear twist upward while it was on jackstands. There are no vibrations that i know of. I had it up to about 95 mph today. The clunk is on exceleration in every gear. Just when it goes into gear.
C
chief44
50
Western PA
Jan 20, 2007
  • Jan 20, 2007
Had to go back and read your post. the shocks were replaced about two years ago.
1TallMF
955
Montreal
Jan 21, 2007
  • Jan 21, 2007
Deffinetly check your control arm bushings and replace as needed. While you're under there, its very unlikely to be the case unless the car has been run hard with drag slicks, but check to see it the torque boxes are cracked at all around the welds. I doubt that would be the case but it happens to be that, its a potentially dangerous situation that should be rectified sooner than later.
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
C
Noisy LCA
  • crazyone64
  • Aug 1, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 2, 2025
manicmechanic007
