Rearend info inside. 31 vs 28
  • Thread starter Thread starter rsw007
  • Start date Start date Feb 12, 2006
rsw007
469
Lexington,SC
Feb 12, 2006
  • Feb 12, 2006
stock carrier to f-150 carrier and stock 28 spline axles to 31spline mosers.
i just finished swapping carriers and axles from 28 spline"mustang" to 31 spline"f150" and rebuilt the trakloc.
the 31 spline axles with 3"studs were 3lbs heavier than the stock axles and studs."EACH" you can see the size diff.
heres the different springs. you can see the f-150 spring is bigger
heres the different size cross pins 3/4" vs 7/8"
rsw007
469
Lexington,SC
Feb 12, 2006
  • Feb 12, 2006
heres a close up of my pitted stock axles. look at the wear at the bearing seats
the stock carrier comes with only 6 cluthes "3 per side" but you can do 4 like i had in mine. but the f-150 comes with 8 clutches "4 per side" heres some burnt clutches.
onefstsnake
792
Northern VA
Feb 12, 2006
  • Feb 12, 2006
Nice.
So my 93 Notch has 28 spline rear end?
Looks like 31 is the way to go.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Feb 12, 2006
  • Feb 12, 2006
Good write-up/post showing the differences.
Weren't the F150 axels longer than the fox mustang axels? What year F150?
rsw007
469
Lexington,SC
Feb 13, 2006
  • Feb 13, 2006
axles were aftermarket mosers not f-150. just the carrier is out of a f-150.
i thought some people would enjoy seeing the difference between the heavy-duty carriers vs the stock stang carrier.
89white50
440
central MA
Feb 13, 2006
  • Feb 13, 2006
sweet!
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Feb 13, 2006
  • Feb 13, 2006
For guys who find scuffed bearing surfaces - the surfaces can be "fixed" with an off-set bearing set that rides a litle further out on the axle on the good surface - just the cost of new bearings.
rsw007
469
Lexington,SC
Feb 13, 2006
  • Feb 13, 2006
yeah, mine were pitted pretty bad. ive cut some low 1.5's and hope next time out to cut a 1.48-1.49. so i know i was living on the edge.
jackchan
507
Mobile Alabama
Feb 18, 2006
  • Feb 18, 2006
as some of you know I am planning on running three NMRA Factory Stock races for the 2006 season and a complete schedule for 2007.....and well I would have liked to have used moser axles myself, but as luck would have it I have to use what I have to save my budget! Hopefully I can make it thru the first two events BRADENTON,FL and REYNOLDS, GA with my stock traction loc and stock axles.....wish me luck!
Jack
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Feb 18, 2006
#10
  • Feb 18, 2006
  • #10
Best of luck to you............
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
