Rearend length
  • Thread starter Thread starter garreett0
  • Start date Start date Mar 17, 2004
G
garreett0
147
houston TX
Mar 17, 2004
  • Mar 17, 2004
I have a 1967 coupe 6 cyl that im converting to v8 and so on. i have a 9 inch rear that i got out of a bronco. Its the beefed up version of the 9 inch. i believe its a little too long. I also want to get moser axles for it. what is an ideal length for it. can anyone help me out?
dodgestang
1,360
Cecil County, MD
Mar 17, 2004
  • Mar 17, 2004
Here is everything you ever needed to know about 9 inch rear and more.....
http://www.kevinstang.com/Ninecase.htm
at the bottom is a link to rear end measurements.
D
D.Hearne
11,730
south louisiana
Mar 17, 2004
  • Mar 17, 2004
If it's from an early Bronco, then I believe it's the right length, but the spring perches will need to be flipped
G
garreett0
147
houston TX
Mar 19, 2004
  • Mar 19, 2004
its from an 84 bronco
D
D.Hearne
11,730
south louisiana
Mar 19, 2004
  • Mar 19, 2004
84 Bronco, then you'll have to narrow it along with flipping the perches.
allcarfan
The Answer Man
2,458
North Atlanta
Mar 19, 2004
  • Mar 19, 2004
narrowing it, flipping perches, moser axels....
You are talking a cool grand just for that stuff!!
HistoricMustang
2,359
Confederate States of America
Mar 19, 2004
  • Mar 19, 2004
Talk to the boys at Currie. The actual cost to narrow the rear end is not that much. The axles add more and of course the perch relocation would also add. If the axles do not taper at the end they can be cut and re-splined which is not as bad as a new set.
I had less than $500 in mine including new axles and freight to and from California and Georgia.
HistoricMustang
www.historicmustang.com
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
