I am hearing a mechanical noise coming from the rearend on my 2000 Mustang GT. It seems to be based on rotation of the wheels but I cant tell exactly where it is coming from due to the exhaust. I have lifted the car and let the wheels spin at different speeds to determine what is causing the noise but the exhaust drones out the noise when I am under there to determine exactly where it is coming from.
I recently had to change out an axle due to a wreck.
I bent the axle and so I replaced the axle and pack bearing that is located within the axle tube at the hub. I did not replace the axle bearing. I filled the rear backup with the correct oil but forgot to add the Friction Modifier. I drove this for several thousand miles before figuring out I needed to add the friction modifier. I have just added the friction modifier but that did not eliminate the noise.
Can anyone help me determine what this noise is?
I am not sure if it is the axle bearing or maybe the ring and pinion is making this noise.
