  • SN95 4.6L Mustang Tech
rearend problems
  • Thread starter Thread starter 02GT/65coupe
  • Start date Start date May 22, 2005
02GT/65coupe
66
alabama
May 22, 2005
  • May 22, 2005
I have been having this groan sound coming from the rearend sometimes when i turn sharp. well i didn't think anything of it cause the next turn it went away. i have a 5 speed with factory gears and everything too. today it turned into a parking lot then the spot and bolth time it groaned and moaned and started making this poping sound. my buddy said his did that same symptoms before his rearend went out. he didn't say if it was the limited slip thing or what. i'm thinking of getting a KB supercharger and upgrading the rearend anyway to 31 spliners and i'm not sure what rearend unit i want to use. i was told that auburns aren't very good. anyway if anyone knows what is actually wrong with the rearend and comments on what would be some good axles and limited slip piece to install. thanks in advance
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
May 22, 2005
  • May 22, 2005
it's your limited slip. a limited slip rebuild kit ( about 45 bucks) and some friction modifier will fix it.
02GT/65coupe
66
alabama
May 23, 2005
  • May 23, 2005
well i'm more of an engine supention guy so i don't know much about gears, trans, or rearends. but anyway you think a stock rearend would hold up to a 9psi KB kit. cause i'm already working on the other short block to replace the one in it. cause i have heard about the 9psi kit blowing the stock bottom end out over time. anyway thanks for the help
my_03GT
186
DE
May 23, 2005
  • May 23, 2005
Mine was doing the same thing, I changed diff. fluid and added friction modifier, and haven't heard it since.
02GT/65coupe
66
alabama
May 23, 2005
  • May 23, 2005
by the way 03, how do you like your kenne bell. i'm waiting on mine to come in and i can't wait. i ordered a 8psi and also the 9psi pulley, i don't know if i want to put the 9 on there cause thats pushing the limits of the roating assembly.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
