rearend swap ??????????
i have a 95 v-6 body with a 95 cobra 5.0 engine and trans. i want to swap my cobra positive track rear end over. can someone please list the steps of doing sooo and if im going to lower the car i should do it while im doing the rear end right?? i appreciate everyones help on my past post.
It's not that hard. I did it in 4 hours. If you plan to lower the car and do
control arms it would be a good time.
Basically you unbolt the rear calipers, shocks control arms and driveshaft
off the rear end. put the tires back on so you can roll it out of the way.
then bolt the new one back in the way you found it.
It really is that easy to swap it out, but take your time to make sure your
pinion angle is correct so you don't get any weird vibrations.
Good luck
