Rearend... Tires... HELP
  • Thread starter Thread starter TimMcGraw67
  • Start date Start date Oct 6, 2010
T
TimMcGraw67
  • Oct 6, 2010
Hello I have a 91 Saleen I believe they did a Thunderbird Rear Swap, It has a set of 94 Pony Rims and 225 60 16s. I want to go staggered I don't know if it is possible due to the wheel clearance any one ran into this? 225s that I have on the rear let loose too much even in 2nd. Another thing is anyone tow with their mustang? I am getting a hitch and Monroe Max Airs for the rear which should allow 1200 more lbs on the rear so I figure 600 more for tongue weight. Laugh at this but I am thinking on towing a 32ft camper with it is that obsurd? or Possible? I have no Idea on what gears this rear has anyone have an idea? My speedo doesn't work and so I would like to be able to guestimate with RPMs.
ttopstang
306
Birmingham, AL
Oct 6, 2010
  • Oct 6, 2010
you could probably fit a 245 tire. but please take pics of you towing a 32ft camper
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Oct 6, 2010
  • Oct 6, 2010
Pony rims on a saleen? There are sets of American Racing 5 stars that are meant to go on that car on ebay fairly often.
Then you are considering towing a camper with it?
Well, you asked if it is absurd, and my answer would be yes.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 6, 2010
  • Oct 6, 2010
The Saleen Mustangs typically had something other than the Turbo Coupe rear axle. The axles were longer and the disk brakes were different. The Turbo Coupe axles were 3/4" longer per side and the disk brakes were a 10 5/16" vented rotor. I am not sure what the Saleen had, but it was different.
You will want to do a search on 91 Saleen and see what you can find.
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Oct 7, 2010
  • Oct 7, 2010
Towing with mustang= bad idea... Especially a 32ft trailer
Onefine88
Previously 89SSC18
1,422
796
154
Oct 7, 2010
  • Oct 7, 2010
The Fox Saleens used the 5 lug SVO rear disk upgrade. Standard rear wheel and tire sizes were 16x7" on the wheels and 225-50-16 for the tires.
The SSC's used 16x8" DP wheels with 225/50-16's up front and 245/50's in the rear.
However if you plan on towing (NOT RECOMMENDED) a 32' trailer with your Mustang , you had better leave the smaller 225 on the rear.
The rear of that car is gonna sit down on the tires.
You will completely kill that car attempting to pull a large trailer like that. You'd need upgraded engine and trans coolers. Beefier clutch and tranny, and a Bigger rear axel with at least 3.73's. You will smoke your brakes.
Also, unless you install an electric brake controller, you'll never stop a trailer with your Saleen.
Your question Absurd or possible?:
Possible but Absurd!!
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
Tire sizes for pony wheels
  • DemonGT
  • May 3, 2022
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 22, 2022
Mindseye007
Tire size choice
  • MrPerfect2
  • May 30, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2021
01HellionGT
Drivetrain Rear end popping noise
  • sav22rem22
  • Jan 29, 2021
2K
Fox 5.0 Mustang Tech Feb 3, 2021
sav22rem22
