rearend woes???
  • Thread starter Thread starter bigbird99
  • Start date Start date Nov 23, 2009
bigbird99
15
las vegas, nevada
Nov 23, 2009
  • Nov 23, 2009
does anyone know what kind of rear is in a 99 gt? my stang is making a wierd grinding noice when turning either way at low speed in 1st gear. i think i need to replace the gears but when i called the dealership they asked what size rearend i had. i was under the impression that they were all 8.8.
i have 118k on the odometer and had the fluid changed over to synthetic about 1 1/2 years ago. any help would be great.
D
Deleted member 38176
Nov 23, 2009
  • Nov 23, 2009
You have an 8.8" rear. DONT GET FACTORY GEARS REINSTALLED!!!!
If you're going to need to replace the gears, have them replaced with 4.10's! All gears cost the same amount, dont waste your money and replace with factory 3.27's.
patman0911
2,287
Tuscaloosa, AL
Nov 23, 2009
  • Nov 23, 2009
Could just be the Tack-Lok binding/grinding/chattering at low speed. At almost 120K it's probably time for a rebuild anyway. I wouldn't think anything's wrong with the actual gears though.
Yeah, all GTs & Cobras have a 8.8" but V6s have a 7.5" though, maybe that's why they asked - those guys have to keep up with a lot of different models and can't necessarily keep track of all that trivia in their heads.
D
darkside03gt
851
Sacramento CA
Nov 23, 2009
  • Nov 23, 2009
As stated dont get factory 3.27s installed if your going to rebuild your rear end.
F
fromadig91
95
  • Nov 23, 2009
+1 on the trac-lok probably needing to be rebuilt
bigbird99
15
las vegas, nevada
Nov 23, 2009
  • Nov 23, 2009
any thoughts on taking it to the factory? i am a little sketchy, every time i have brought it to the factory (only 2wice) they freak out!! they say they dont work on saleen's (mine is a clone) i tell them that it is a clone and they seem to be afraid to work on mustangs that are modified?? might is slightly modded, body kit, rims & tires, shocks & springs, intake, exhaust.
patman0911
2,287
Tuscaloosa, AL
Nov 23, 2009
  • Nov 23, 2009
Rebuilding the Trac-Lok really shouldn't be a big deal for a dealer, but ask around, there's gotta be a reputable transmission/driveline shop nearby that can do it, and probably for less than the dealer. They can verify for you that it's the Trac-Lok and not the gears too so you don't pay for repairs you don't need.
If you do a burnout, do both wheels still spin or just one? If just one, it's definitely worn out.
It's possible that it's still functional. If you changed the fluid and didn't add the recommended friction modifier, that could be why it's making more noise when turning at low speed. How long has it been doing it?
bigbird99
15
las vegas, nevada
Nov 23, 2009
  • Nov 23, 2009
its been about 2 months and i am worried, there is also a smell, sometimes smells like oil, and somtimes antifreeze and it smells like it is coming from under the hood, not the rear??? any thoughts???
patman0911
2,287
Tuscaloosa, AL
Nov 23, 2009
  • Nov 23, 2009
Well, that sounds unrelated to the rearend issues. There could be many sources of those smells...
Coolant could be coming from cracked intake (very common issue on 96-01 Mustangs and other 4.6l), over-filled overflow tank dumping excess coolant, overheating causing coolant to boil over, pin hole in radiator, leaking hose, leaking intake manifold gasket or water pump gasket, bad water pump...
Is it loosing a noticeable amount of coolant? Can you tell where it's going? The first places to look for coolant is in the block valley, spark plug holes and on the front of the block and oil pan. If it's a small leak, it can be hard to find sometimes though - a few drops of burned off coolant can really stink things up.
Oil smell is under the hood and not in the exhaust, right? Any visible smoke under the hood when you smell the oil? If so, see if you can trace it to the source. The PCV system is the first place I'd look - when's the last time the valve was replaced? Make sure the hoses are all in good shape - no rotting or cracking. While running, look for oil dripping from a valve cover gasket.
bigbird99
15
las vegas, nevada
Dec 2, 2009
#10
  • Dec 2, 2009
  • #10
new gears (and axles) and same grinding noises???
just got my new gears installed (3.73) and had to replace the axles as well. but the same grinding noise is coming from the rearend. to boot, now the speedo is off!!! does anyone know how much the speedo is off from going from 3.27 gears to 3.73 gears? i plan on getting it calibrated but it might be a week or so, so i want to know how off it is. today i was cruising and it felt like 70 or so but the speedo was reading 85???
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
