Rebuild or Replace
DStang99
46
Florida
Hello Stangnet,
I Have a 1999 mustang gt with 160k Miles that has a loud knock at high RPM .
Should i just buy a used motor or just rebuild it if rebuild is best what all should i replace? What can i replace to gain more Power?
Define high rpm. When does the knock specifically occur? Off hand, I can't think of any knocks that are only present at high rpms, so it is possible you don't have to replace the entire engine.
The motor only knocks when i get on it or when i rev it in park it starts to knock.
not sure what rpm it starts. I have been told i blew a rod bearing
A rod bearing will typically be loudest at light loads and moderate rpms. For example, reving in neutral or in light driving to 2000-2500 should produce about the loudest knock. I think of high rpms as being 4krpm, so if your knock doesn't start until 4000 rpm, then it probably isn't a rod bearing.
Sounds like a stock replacement bottom end would work fine for you.
Not sure what your plans are, but I'd go find a Mark VIII short block from the local junk yard, have valve reliefs cut into the Mark pistons and run some nice high lift cams. High compression cammed 4.6 FTMFW :nice:
You already have most of the parts there to do this swap, and you'd benefit from the lighter aluminum engine block.
