  • SN95 4.6L Mustang Tech
Rebuilt kit
  • Thread starter Thread starter pompimike
  • Start date Start date May 15, 2006
First Prev 2 of 2
01Steeda
732
Baton Rouge, LA
May 17, 2006
#21
  • May 17, 2006
  • #21
Gearbanger 101 said:
I was going to go back and change all of my previous posts that stated only the rods and piston needed to be balanced....but then I remembered that almost nobody listens to me anyway and the ripple effect would have been minimal.
Did u say something
honestly I usually read a post if I see you have responded to it last even if I am not to intrested in the topic, thier are a few members I will do that with, hotmustang, svttech, billfisher.
P
pompimike
#22
  • May 17, 2006
  • #22
Well, if it's a do it yourself deal, I'd go with the Stage 1 kit shown here. If your stock crank is still in good condition, it's suitable to use about 600hp+ with a 2V engine and most street level blower kits won't be pushed anywhere near that hard anyway.
Just don't forget you're going to have to have the crank balanced afterward to the rods and pistons (about $150) unless you go with the pre-balanced crank option with the kit (another $550 on top of the kit price). I made the mistake of not doing this and now I find myself tearing everything apart again after my install to have it donw.
About the the Stage 1 kit when i go to it, it shows me the one for the dohc. i have to pick the one with the sohc one right. Where did u see the price for pre-balance crank option, show me the web site.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 17, 2006
#23
  • May 17, 2006
  • #23
Stage 1 kit is the very first one on the link I gave you (when you click on piston type, it has an option for both the SOHC and DOHC engine) You'll want the 19cc pistons. The new pre-balanced crank option is the 4th one down in the link.
P
pompimike
#24
  • May 20, 2006
  • #24
Why do you think i'll want the 19cc pistons....what size throttle body should i go with 70 or 75mm?
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 20, 2006
#25
  • May 20, 2006
  • #25
You'll want the 19cc slugs to keep compression ratio where you want it for a blown motor. And all blown engines will benefit from a larger throttle body, so go with the 75mm if you're indecisive between the two.
P
pompimike
#26
  • May 21, 2006
  • #26
yeah but my engine isn't blown.....
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 22, 2006
#27
  • May 22, 2006
  • #27
Well, you stated in post #5 that you might be getting blown in the future. The 19cc slugs will work well with N/A and power adders. If you know for sure you're going to stay N/A or run nitrous as a power adder, then by all means go with the higher compression for maximum effect, but if not, high compression pistons won't allow you to run much boost or timing with a forced induction application.
P
pompimike
#28
  • May 22, 2006
  • #28
well the thing is the engine is not blown or its gonna blow soon. The motor just coming up on 100k and i've never had a problem with it. But as for power i think i might with the old sc...so those pistons won't do the work. Because n/a i'll never get the same power, unless i go with nitrous. And for the money i rather go with the sc.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 22, 2006
#29
  • May 22, 2006
  • #29
Just to clarify, If you're going N/A, with the possibility of a blower in the future, stick with the 19cc slugs.
First Prev 2 of 2
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
Swapping clutch pedal hanger-
  • woodsnake
  • Sunday at 3:55 PM
Classic Mustang Specific Tech Sunday at 3:55 PM
woodsnake
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 1:54 PM
limp
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
