  • SN95 4.6L Mustang Tech
Recalls are finding Me!
  • Thread starter Thread starter trombonedemon
  • Start date Start date Oct 10, 2009
First Prev 2 of 2
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 16, 2009
#21
  • Oct 16, 2009
  • #21
Well, if you are trying to save money there are parts guys selling OEM parts cheap on the internet like Tousley Ford. Also, Rock Auto always has good deals on OEM parts.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Oct 22, 2009
#22
  • Oct 22, 2009
  • #22
O.k. update, its not the Multi-switch, I replaced it and still no wipers. So my guess is that the electricity went opposite and damage my relay and made it stick on off since thats what it was on when the wires hit the gear stick. So I'm off to replace the relay, hope this works, and somthing funky happened! My lights on my gauges cut off b/c of the ground wire, now they are back on with the ground wire gone. Anyway, any more suggestions will be helpful!
P.s. All of the neccesary fuses are intact!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 22, 2009
#23
  • Oct 22, 2009
  • #23
Pinpoint tests
I am going to chime in on this thread one more time and then disconnect.
While the fuse itself has been tested good, has the power to/from the fuse been positively verified? If not, recommend removing the fuse, test for 12V power between the empty socket and a known good ground (in run or acc). Test both sides of the fuse socket (expecting power in only one side).
Unless there is power coming out of fuse F1.4 AND F2.26 in acc/run, the wipers will not work.
Previous posts seam to indicate there is NO POWER from the fuses. In any case, it is not clear to me what additional tests have been done and their results.
Where the power is/is not will tell us where to look next.
What to do next if there is power in Fuse F2.26:
Since you stated that both the wipers and the washer motor do not work, it is unlikely to be the Wiper relay (K316/K140) and the washer relay (K139) failed at the same time.
To rule this out, ground out pin #1 on the K139 washer pump relay (engine compartment LH side). The wire color is #20 TN/RD. If the washer pump runs, then the problem is either in the wiring harness (unlikely), multi-function switch (already ruled out), or the Generic Electronic Module (GEM).
The GEM is serviced as an assembly.
What to do NO POWER in Fuse F2.26.
Check Fuse F1.4. If power in F1.4, the problem is in the wiring harness between the BJB and CJB.
If no power in F1.4, it is a power distribution problem perhaps in the ignition switch. Let’s cross that bridge if needed.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Oct 23, 2009
#24
  • Oct 23, 2009
  • #24
Hey W.M. Burns, thanks for the help! I'm kinda embarrassed to say what it was to begin w/but, you were right, really! Please continue to post really helpful information! Stangnet, W.M. Burns
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 23, 2009
#25
  • Oct 23, 2009
  • #25
Does that mean it was a fuse? Which one? What was the final resolution and how did you find it?
You know that sometimes a car problem is like a mystery novel. If you skip to the end, you miss out on all of the fun. It almost as much about the process as it is the results.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Oct 23, 2009
#26
  • Oct 23, 2009
  • #26
Yea, it was the fuse!!!
First Prev 2 of 2
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
F
Wiper motor relay? Motor? Multifunction switch?
  • Flinchum87
  • Jul 15, 2024
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 15, 2024
Flinchum87
F
For Sale Cobra II part out
  • 76_Cobraii_mustang
  • Dec 15, 2023
  • Mustang II Parts
3K
Mustang II Parts Oct 31, 2024
78GhiaMustang2
C
64 1/2 gen issues
  • corvairbob
  • Jul 29, 2023
Classic Mustang Specific Tech Jul 29, 2023
corvairbob
C
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
